20 Most Recent
Simrad Ap14h Hydraulic Powerpilot Questions & Answers
Hi,Steve from Australia.I have a AP14H and am now having problem
seems to be a problem with the rudder feedback sensor first check if rudder sensor is not mechanically disconnected,if not try to do de setup procedure,reset the unit to factory condition,try to set rudder limits,if this is not working ,check with other feedback unit.
My simrad ca44 keeps turning itself on and off
This is almost always a power supply issue. Check and clean your positive and negative connections. Although the link below is for car batteries, the principles are the same.
If that gives you no joy, check the plug and socket of your unit. It doesn't take much corrosion to render an electronic device inoperable.
Hope this helps.
-Steve
How to Clean Car Battery Terminals
