20 Most Recent Rolex Datejust (538) Watch for Women Questions & Answers
The running ime for a self einding watch (which I presume tha yours is) varies from maker to maker and model to model.
I explored their web site but was unable to find anything useful about running time.
Most other types run for a time in the range 36-72 hours and 12 hours seems rather mean as it does not allow much more than sleeping time before it stops.
I suggest that you approach the supplier and discuss it with them.
Rolex Datejust... | Answered on Nov 26, 2010
The watch needs to be serviced. Its a great watch and the service wont be cheap but you will get it back in wonderful shape. A good repair shop can do this work, try a yelp search in your area.
Rolex Datejust... | Answered on Oct 08, 2018
Some movement noise is ok, however it may be time for a service - Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
Rolex Datejust... | Answered on Feb 11, 2018
Its time for a service.
I have the same watch 20 years old. I cannot wind this watch.
it is self winding , which is generated by arm or wrist movement.
i purchased a box for times I won't be wearing. Will rotate watch 5 minutes every hour ( belt driven- only use that other winders say gear my experience is belt drive more reliable)
if you have to wind this watch I would question if it is real Rolex.
Rolex Datejust... | Answered on Sep 21, 2016
It needs to be worn to self wind. I actually bought a winding box so I put watch away it will be turned as if on your wrist. These vary and having owned a couple of winders I chose one that is belt driven, found on Amazon.
if you wear it to sleep it may wind down.
Playing video games ,little wrist motion, may find it stopped.
you mentioned someone to.d you it was fully wound! How can they tell. I cannot wind mine if yours needs winding from stem you may not have real Rollex.
try winding by using the crown see how long it goes for it may be the bob weight is not working or as come loose
Rolex Datejust... | Answered on Jul 16, 2016
you cant check a serial number if Rolex dealer checks it he has to keep it if the watch is stolen
Thanks
Watchfinder Sean
Rolex Datejust... | Answered on Dec 09, 2014
Luke, the serial number is located between the lugs at the 6 marker.
You need to remove the wristband at that point to see it. The model number is located at the 12 marker.
Rolex Datejust... | Answered on Apr 04, 2013
Its not unheard of depending on the age of the watch (you say you purchased it 16 months ago but it could be a 15 year old watch.) If it was a new Rolex watch you have a 5 year warranty, so it should cost you nothing. If it was a pre-owned Rolex you should have received a warranty from your jeweler, most of those are 2 years. If this is a watch with value, and one you will either hand down or at some point resell then sending an older watch to Rolex is the proper direction - save all the repair documents, with the original receipt and the box. A Rolex Explorer II in good condition in US is about $5k, so $380 for a repair, though high, is worth it. I would recommend that if you do send it to Rolex for this repair and it is an older watch have it serviced too. The watch is returned to you in perfect condition with fill documentation.
Lastly, you need not to send it to Rolex at all. Any good watchmaker/repair jeweler can do this for less than $380US.
Rolex Watches | Answered on Jun 08, 2020
https://www.youtube.com/watch?v=RzQcj1ulIkQ
"Five hundred dollars for a '93 Rolex Daytona," he says, "I'll do it!" That same watch is valued at around $16,000-$19,000 now, depending on its condition.Jul 30, 2012 https://www.exquisitejewelersmiami.com/blogs/rolex-daytona-watches/6351872-the-rolex-daytona
Rolex Daytona Size and WeightDaytona watches are large and typically measure 40mm across. Weight for the Rolex Daytona varies based on the material used. For instance, it ranges from 148 grams for the stainless steel model, to 195 grams for the white gold, to 283 grams for a platinum Rolex Daytona.
https://northscottsdaleloan.com/watch-reviews/rolex-daytona/
Rolex Watches | Answered on Apr 29, 2020
Doubtful. if you bought it cheaply. A jeweller will be able to tell. There are many authentic looking knockoffs. :-)
Rolex Watches | Answered on Jul 17, 2019
Rolex Datejust (538) Watch for Women Logo
3 questions posted
Top Rolex Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
View Most Popular
Datejust Rolex
  • Datejust Rolex
Most Popular Question
date just stops 12 hours after
  • Watches
