20 Most Recent Armitron Round Digital Sport 408089 Watch Questions & Answers
many ani digi watches have to batteries , one large lithium to run the digital and then a smaller 377 silver oxide battery to run the analogue movement.
the smaller battery is usually directly below the lager battery in a small cut out in the printed circuit board.
Armitron Round... | Answered on Feb 06, 2018
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron Round... | Answered on Jun 11, 2015
Hi, According to your requirement, you have to purchase the strap. You can contact with nearest Armitron dealer or you can visit http://www.armitronservice.com for a replacement of strap. their mail id is [email protected] and contact number is (248) 767-8927. You can purchase the same strap from http://www.bizrate.com/watches or http://www.amazon.com. Just visit and choose your product and add it to cart. Purchase your product online by a valid credit card with postal information.
Armitron Round... | Answered on Aug 29, 2011
when setting in the mode for time ect get to the date and press lower right button or top. it changes from day month or month day
Armitron Round... | Answered on Jun 17, 2011
Hello, Ilbrownkid,
You can find Armitron Watch Instructions at the Armitron website. I've included a link below for your convenience.
http://www.armitron.com/watch_instructions.asp
Please let me know if I can be of further assistance to you.
--Sandy
Please be sure to Rate this message! Thanks!
Armitron Round... | Answered on May 10, 2011
Make, model, all numbers, please.
Armitron Round... | Answered on Apr 03, 2011
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Armitron Round... | Answered on Jan 10, 2011
Hold A, and B and press C, mine shut off
Armitron Watches | Answered on May 27, 2020
https://www.google.com/search?sxsrf=ALeKk03ImG5jnwrgpUNEF1NguJCtutYntQ%3A1584120963230&source=hp&ei=g8RrXtn5C-2DhbIPjIiTyAI&q=How+do+I+change+the+date+on+Armitron+40%2F8428&oq=How+do+I+change+the+date+on+Armitron+40%2F8428&gs_l=psy-ab.3...27980.27980..29265...1.0..0.334.334.3-1......0....2j1..gws-wiz.7rBjSw__yjA&ved=0ahUKEwiZx6u6_pfoAhXtQUEAHQzEBCkQ4dUDCAU&uact=5#kpvalbx=_tMxrXtPWJOijgwezrKto34
Armitron Watches | Answered on Mar 13, 2020
Take your Armitron watch to a jeweler who will identify battery type (not size) and perhaps install a replacement.
Armitron Watches | Answered on Dec 22, 2019
Armitron Round Digital Sport 408089 Watch Logo
24 questions posted
Top Armitron Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
ray gallant
Are you an Armitron Watch Expert? Answer questions, earn points and help others
View Most Popular
Armitron Watches
  • Armitron Watches
Most Popular Question
armitron 20 1277 79 81 watch bought
  • Watches
