20 Most Recent Liebherr KES3660 Stainless Steel Refrigerator Questions & Answers
The defrost timer sticks in defrost mode and then comes out of it. I've been out of the service industry long enough to not be able to tell you on your model where it is located. Defrost timers on frost free refrigerators are a very common problem.
Liebherr KES3660... • Answered on Oct 11, 2017
the fridge probably isn't quite level - or tilt the side that is holding the water slightly so it down to the drain hole - 1/8" could make the difference
Liebherr KES3660... • Answered on Jul 04, 2011
If the ice has build up more than 1 cm on the coils then yes, it must be defrosted. This is extremely simple: you empty the fridge, unplug it from the mains and you let the doors open - the air will thaw the ice. Just clean from time to time the accumulated water. Once all the ice is gone wash the insides clean (don't forget the water drainage hole at the bottom of the rear panel of the fridge section), dry it, put the food back in and start it again. It's a 3 to 6 hours job, depending on the amount of ice and how hot is in the kitchen. This must be done at least once a year, even if the ice isn't building up.
The liquid is just vapours coming from the meat and other foods that have condensed on the door because the refrigerator was no longer capable of properly cooling them - a clear sign that it should have been defrosted long ago.
Liebherr KES3660... • Answered on Jun 13, 2011
Bonjour, J'ai le même problème. Avez-vous trouvé la solution ? Savez-vous où est le thermostat sur cet appareil ? Merci Cordialement Eric
Liebherr KES3660... • Answered on May 22, 2011
syringe out with clorine bleach(neat)then rinse,as clorine is a gas the smell will go in seconds.
Liebherr KES3660... • Answered on Aug 25, 2010
As you had done switch off the fridge. now after the frost had cleared off , keeping the fridge a little away from the wall switch on. But only after you have checked for the thermostat to be set to normal, the fan working fine as well as the timer switching on the auto defrost. So look out for the compressor to shut off when the thermostat reaches the limit, if this wont work then the ocmpressor will run and result in heavy frost. so it can be that the wires to the thermocouple is broken or damages due to frost. so you can open freezer compartment and confirm on inspection of the wiring for any breaks.repeat if frost appears till you correct and confirm. If you are calling a repairman keep this mind so as to get an idea of the work, to have an estimation of the work. Hope you try this out. Good day
Liebherr KES3660... • Answered on Aug 12, 2010
Thanks for writing to Fixya.com.
Please use a little air pressure to clear drain lines, than pour a diluted solution of water and a little bleach down the hole water should drain fast and not pool.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Liebherr KES3660... • Answered on Jun 09, 2010
2005 thats not old & compressor should be fine. Have the thermostat control checked first, if it is not that it is possibly the capacitor on the start relay at fault. Can you tell me what gas is in the system, and the numbers on the side of the compressor.
Liebherr KES3660... • Answered on Apr 18, 2010
t-cut car polish. I don't hold out a lot of hope on stainless.
Liebherr KES3660... • Answered on Mar 27, 2010
Liebherr GNES 2866-20B, wont come on how do i get it out of demo mode
Liebherr KES3660... • Answered on Mar 02, 2010
try unplugging the unit,
sometimes this clears the eprom and it returns to default run
Liebherr KES3660... • Answered on Oct 17, 2009
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Liebherr KES3660... • Answered on Sep 21, 2009
The ventilator fan causes the water to evaporate from the drain pan. There may also be a heater element to do it as well. Without it nothing is making the water evaporate so it is overflowning. Might be the fan motor or the switch that is a problem.
Liebherr KES3660... • Answered on May 05, 2009
That's not the way it works. Normally you contact a company and say "I want door gaskets for a Liebherr CS 2062". Let them worry about part numbers. They are here https://www.letstalkparts.com/Liebherr-Appliance-Parts-s/283.htm https://www.google.com/search?q=Liebherr+fridge+CS+2062.+doors+gaskets ..
Liebherr... • Answered on Apr 07, 2021
The Spaminator Mar 22, 2021 Hi Jasmin Black, I suspect ice build up behind the back panel of the freezer could be causing this. this could be due to a faulty thermostat transducer that tells the freezer to defrost when the ice builds up.
Liebherr... • Answered on Mar 22, 2021
first check the freezer compartment temperature
Liebherr... • Answered on Dec 04, 2020
Liebherr KES3660 Stainless Steel Refrigerator Logo
27 questions posted
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
john h
Paul Carew
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
freezer overflowing ice as
  • Refrigerators
