20 Most Recent Elna 945 Computerized Sewing Machine Questions & Answers
Try Central sewing Machines in Edmonton Alberta. Looks like they have it in stock
Elna 945... | Answered on Aug 22, 2014
At your Elna dealer, at just about any sewing machine repair service, or if you don't have one locally, try Ron Anderson at A1 Sewing:
[email protected] I've known him on the net for about 20 years, and he's quite helpful.
Elna 945... | Answered on May 25, 2014
Make sure power is turned off. Get a pair of pointy nose pliers (may need to try a couple of sizes to get correct one). Use these to get hold of the metal light base and remove. Will probably need to turn base to release. Then insert new bulb.
Elna 945... | Answered on Jan 20, 2014
check with a1sewingmachines.com for the part
Elna 945... | Answered on Apr 02, 2013
here is a link to the service manual for the 925 http://www.arizonaexpressionz.com/elna_service/925_704%20suppl.%20service%20manual.pdf
I can't see one for the 945 but the above manual may give you some guidance as to what the replacment involves.
945 is a fairly new model so you may find that taking it to a pro and getting the timing and loopers checked at the same time is worthwhile. Also being computerised model, if you get something wrong and the computerised part is affected it could turn out more expensive to then take it to an Elna dealer.
I get my Bernette serger serviced every 2 years and it is now over 19 years old, and still performing well.
Elna 945... | Answered on Jul 05, 2011
Thread the lower looper like normal, and you needle. When the upper looper comes up it will push up the lower thread and then you can put it under the pressure foot torward the back and start to serge.
Elna 945... | Answered on Apr 25, 2011
Is the tension on the left needle on its normal setting and is the thread feeding okay to this needle, not caught up somewhere on the aerial or around the cone?
You could try unthreading everything, changing the needles, then rethreading the machine again in the sequence of the threading diagram and test sew.
However, if you have had this machine for a while and are very used to threading it and this seems like a fault to you, then it could be that the looper has been knocked out of timing and it would need a trip to the sewing shop to investigate further.
Elna 945... | Answered on Apr 08, 2011
try this link http://www.youtube.com/watch?v=bC-bJE5zwzw&feature=related for movie of a Pfaff piping foot in action, the principal would be similar, you are wrapping bias strip around cording on left of foot and overlocking right side. You can also do this with fabric top and botton thereby inserting the piping as you make it.
I have not tried this technique myself as I've only bought a blind hem foot for my Bernina but must admit I have used that a bit in the past.
Most serging techiques are very similar across the brands.
Elna 945... | Answered on Mar 07, 2011
Hi!!
You can order parts and accessories for your Elna Serger Sewing Machine on the following places:
http://sewingsupplywarehouse.com/elnasergerfeet.html
http://www.sew4less.com/
http://www.whitesewingcenter.com/elnaidentify.php
Good luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Elna 945... | Answered on Feb 23, 2011
try sewingpartsonline.com
Elna 945... | Answered on Nov 30, 2010
Hi,please clearly state your problem in a good description to enable you to get a more comprehensive solution.
Thanks and good luck
Elna 945... | Answered on Jun 08, 2010
The thread is bit loose while you are stitching .Keep the thread tight then check reverse side it will be perfect.
The procedure is as follows:--
The triple cover hems flattens the over-lock seam eliminating excess bulk and allows maximum stretch and comfort.The top stitching is quick and attractive.
Sew ribbing to the fabric using 3 thread wide or safely 4 threaded stitch.Then set up the machine for triple cover hem.The seam may be positioned either towards ribbing or towards the garment fabric.top stitch by allowing the center needle to stitch in the ditch .The outer needles will top stitch on the fabric and on the ribbing in one step.
Note:-- It is acceptable to use cover hem wide for top stitching and over-lock seam.The chain looper  thread should be tightened to keep the over-lock seam as flat as possible.This will make the reverse seam look perfect.When the looper thread is tightened the fabric may pucker and the capacity of stretch is decreased.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Elna 945... | Answered on Jun 07, 2010
Elna 945 Computerized Sewing Machine Logo
32 questions posted
Top Elna Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Nick Olsen
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Elna Sewing Machines
Most Popular Question
elna 945 computerised overlocker am am
  • Sewing Machines
