20 Most Recent Necchi 6150 Sewing Machine Questions & Answers
Do you know of someone who gives lessons on Necchi 4825?
Instructions normally come via the manual, but you might find a sewing club. https://www.google.com/search?q=Necchi+4825+manual https://www.google.com/search?q=Necchi+sewing+club+near+me ..
10/12/2023 4:14:40 PM • Necchi Sewing... • Answered on Oct 12, 2023
I have a Necchi model BU, Serial number U168785 in a wood cabinet. Where do I find the manufacturing year? Also, where do I find a free PDF owners manual? Thank you.
The manual is $4.99. https://manualsoncd.com/product/necchi-bu-sewing-machine-instruction-manual/ This says Free https://millardsewing.com/product/necchi-model-bu-mira-instruction-manual-free-download/
How To Date A Necchi Sewing Machine - SewingFeed
sewingfeed.com https://sewingfeed.com > how-to-date-a-necchi-sewing... Mar 6, 2023 - The easiest way to date a Necchi sewing machine is by identifying the model you have and then researching what year it was made in Necchi brand ... ‎Where Is Serial Number On... · ‎Where is the model number on...
How Old Is My Necchi Sewing Machine? (Vintage ...
SewingIsCool.com https://sewingiscool.com > how-old-is-my-necchi-sewi... Finding the age of the Necchi sewing machine that you personally own doesn't take too much effort. You need the serial number and possibly the model number.
Necchi Sewing Machine Serial Numbers ' Peatix
Peatix https://necchi-sewing-machine-serial-numbers269.peatix.com The BU is a flat bed machine with an oscillating hook and manual zig zag (which I believe means you select zig zag by shifting the stitch width lever rather ... ..
9/13/2023 12:42:42 AM • Necchi Sewing... • Answered on Sep 13, 2023
Necchi model 3355. I can't put the bobbin and bobbin case back into it?
They will only go in one way, they have to be correctly orientated. https://www.google.com/search?q=Necchi+model+3355+replace+bobbin+case ..
9/12/2023 11:31:45 PM • Necchi Sewing... • Answered on Sep 12, 2023
Necchi Alco 1300SU Sewing Machine. I need a owner's manual please?
Question edited for clarity. Question moved to Necchi category. This appears to be a tricky machine..... By this time most manuals were generic like that without a name on them, there were so many badged identical machines that a separate printing for each name was out of the question. So many machines didn't even get a badge until they reached their destination country. No manuals for it. Set a watch for it on eBay. There are similar Necchi. https://www.google.com/search?q=Necchi+Alco+1300SU+manual https://necchi-usa.com/pages/support ....
9/9/2023 6:21:39 PM • Necchi Sewing... • Answered on Sep 09, 2023
Necchi 16A stopped cold when sewing
take it back to the place where you took it two weeks ago. Otherwise, need more info...where in the machine did it wrap?
6/27/2023 7:05:19 PM • Necchi Sewing... • Answered on Jun 27, 2023
Necchi sewing machine. How to fix the stitch length regulator please?
Fix in what way? What is wrong with it?
5/17/2023 3:51:17 PM • Necchi Sewing... • Answered on May 17, 2023
Necchi Lydia 3 - I can't get the tension on my upper thread adjusted. I have turned to different numbers on the dial but there is a mess of thread on the underside. The bobbin tension correct.
Is this machine new to you or have you had it awhile and it worked fine before?Are you sure it is top thread?... use a similar but contrasting color for top thread to be sure.Do you have the manual to be sure you are threading it properly?See following video on threading the Lydia 3.https://youtu.be/wVifJVsrO80Comment below for further assistance.
5/4/2023 6:46:19 PM • Necchi Sewing... • Answered on May 04, 2023
2answers
Exercises to relieve pain from spinal stenosis
Spinal Stenosis Surgery Spinal stenosis surgery by expert laser spine surgeon Todd Gravori in LA. Book an appointment & get spinal stenosis treatment done with laser spine surgery. Know more here: Spinal Stenosis Surgery Treatment Los Angeles ProMedSPINE
3/2/2023 10:36:10 AM • Necchi Sewing... • Answered on Mar 02, 2023
Necchi Q132A needle postioning dial doesn't work
If the needle positioning dial is not working on a new out-of-the-box Necchi Q132A sewing machine, it could be a manufacturing defect or a loose connection. Here are some steps to troubleshoot the issue:
  1. Check the manual: Make sure you are following the correct steps to use the needle positioning dial. Refer to the manual and double-check if you are using the dial correctly.
  2. Check the connections: Open up the machine and check if all the cables are securely connected. If any of the wires are loose, reattach them carefully.
  3. Contact the manufacturer: If the above steps do not solve the issue, contact the manufacturer or the seller from whom you purchased the machine. Since the machine is new, it should be under warranty, and they should be able to provide you with the necessary support or even a replacement if needed.
  4. Take it to a repair shop: If the machine is out of warranty, or you prefer not to deal with the manufacturer, take the machine to a reputable sewing machine repair shop. They will have the expertise to diagnose and fix the issue.
Remember not to attempt any repairs yourself as it could void the warranty or cause further damage to the machine.
2/24/2023 2:59:06 PM • Necchi Sewing... • Answered on Feb 24, 2023
Can't get my needle to tighten in my necchi nc204d
It sounds like there may be an issue with the needle clamp on your Necchi NC204D sewing machine. The fact that the needle falls out when you try to tighten it suggests that the clamp may not be holding the needle securely. Here are a few steps you can try to fix the problem:
  1. Check the needle clamp: Make sure that the needle clamp is tightened properly and that the screw is secure. Also, make sure that the needle is inserted all the way into the clamp.
  2. Check the needle: Make sure that you are using the correct type and size of needle for your machine. The needles that came with the machine should be the correct size, but it's good to double-check.
  3. Check the needle plate: Make sure that the needle plate is clean and free of any debris or burrs that could prevent the needle from seating properly.
  4. Check the needle alignment: Make sure that the needle is aligned properly and that the flat side of the needle is facing the back of the machine.
  5. If the problem persists, it's best to contact Necchi customer service or a professional sewing machine technician for further assistance.
It's important to note that working with a sewing machine can be dangerous, if you're not comfortable working with it, it's best to get it serviced by a professional.
1/23/2023 10:45:03 AM • Necchi Sewing... • Answered on Jan 23, 2023
Necchi foot pedel just hum's doesn't work, why?
if your machine has this slide button on the motor casing maybe you need to switch it back and forth a couple of times
12/12/2022 2:53:16 AM • Necchi Sewing... • Answered on Dec 12, 2022
Why does my necchi sewing machine start seeing on its own when plugged in
The foot pedal needs cleaning inside, or it needs replacing.
11/18/2022 6:24:42 AM • Necchi Sewing... • Answered on Nov 18, 2022
Where can I download a free necchi 4575 manual
No free ones. $15 in the first link. https://www.google.com/search?q=necchi+4575+manual ..
10/30/2022 5:35:16 PM • Necchi Sewing... • Answered on Oct 30, 2022
I have a Necchi 3355 and the stitch selector is stuck. Please help.
Hi, Please add a bit of some olive oil (or similar oil) to shafts and areas of your machine that facilitate the selector's movement. This should lower friction and allow for movement. Thank you.
10/14/2022 1:28:31 AM • Necchi Sewing... • Answered on Oct 14, 2022
2answers
What are some brain facts?
Hello, Go too this website for brain facts: Fun Brain Facts for Kids Interesting Facts about the Human Brain
9/29/2022 4:51:54 AM • Necchi Sewing... • Answered on Sep 29, 2022
Cannot find spare parts for servicing an old Necchi 559 household sewing machine.
Have you tried Nacchi ... https://necchi.uk/product-category/necchi-spare-parts
6/7/2022 6:25:56 AM • Necchi Sewing... • Answered on Jun 07, 2022
Necchi 6018. Where can I find a walking foot for my Necchi 6018? Thanks.
Only from the maker by the looks of it. https://necchi-usa.com/search?q=walking+foot Not available from the normal outlets. One on Amazon but not for your machine. https://www.google.com/search?q=necchi+6018+walking+foot ..
3/23/2022 7:26:16 PM • Necchi Sewing... • Answered on Mar 23, 2022
2answers
Necchi 6150 Sewing Machine Logo
0 questions posted
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Necchi Sewing Machines
Most Popular Question
get needle tighten in necchi nc204d
  • Sewing Machines
