20 Most Recent Husqvarna Scandinavia 100 Sewing Machine Questions & Answers
Hello
You may be able to obtain a replacement foot pedal from you local Husqvarna Viking dealer.
Happy Stitching
Sewingirl/
Husqvarna... | Answered on Mar 20, 2017
The best way is to take it to an authorized repairman.
You can try getting it very warm, like putting it in the warmest sunlit room in the house, or in the back seat of the car in sunlight. If it works better when it gets warm, the reverse mechanism will need to be cleaned. Then you can take it to an authorized repairmain.
Husqvarna... | Answered on Mar 08, 2017
You might start with contacting Husqvarna's Customer Service.
Their USA contact info is:
SVP Worldwide
C/O Husqvarna Viking
P.O. Box 7017
LaVergne, TN 37086-7017
Toll free assistance - 1-800-446-2333
Monday-Friday 8:00 am - 4:00 pm CST
Email:
[email protected]
(Please allow 72 hours for response)
Best of luck!
Husqvarna... | Answered on Feb 24, 2016
Give www.Manualslip.com a try. I download mine manual as a PDF forms and print it out myself.
Husqvarna... | Answered on Mar 09, 2015
I would try ebay.com
if you don't have the accessory that looks like a short piece of rubber hose used to remove and reinstall the bulb, take the machine to an authorized Viking repair dealer and ask them to install a new bulb.
Husqvarna... | Answered on Feb 09, 2015
Check the user manual. You can view, download, or print the manual free from the viking website - http://www.manuals.husqvarnaviking.com
See page 11.
Changing the Presser Foot ! Turn off the main switch
  1. Make sure that the needle is in the highest position. Pull the presser foot towards you and slight pressure downwards.
  2. Line up the cross pin on the foot between the spring and the presser foot ankle. Press back until the foot snaps into place
Husqvarna... | Answered on Oct 16, 2014
The pressure foot knob had some problems. on this model. The solution was to remove the covers and the e clip that holds the knob in place. I install a belleville spring washer on the knobs shaft. This extra tension keeps the knob from turning when the sewing machine vibrates. This may be more difficult than most consumers want to attempt.
Husqvarna... | Answered on Oct 13, 2013
Most machines need periodic lubrication (oil, grease, or both) and typically the external covers will have to be removed to get at the parts that need the lubrication.
Husqvarna... | Answered on Feb 12, 2013
Do a web search and you should find what you need either through E-bay or a parts supplier. Example - type in: "scandinavia 100" "power cord"
Husqvarna... | Answered on Jan 31, 2013
Does you machine go in reverse and just not sew in reverse? If this is the case you might have a feed timing problem. Clarify your exact situation.
Husqvarna... | Answered on Apr 27, 2011
You may use the upholstery thread in the needle, but not the bobbin. Use standard size thread in the bobbin. If you absolutely need to use the upholstery thread in the bobbin, you will need to adjust the upper and possibly lower tension in order for it to work.
Husqvarna... | Answered on Feb 26, 2011
Husqvarna Scandinavia 100 Sewing Machine Logo
35 questions posted
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Husqvarna Sewing Machines
Most Popular Question
oiling 100 model
  • Sewing Machines
