20 Most Recent Husqvarna Interlude 445 Sewing Machine Questions & Answers
If it is a computerized machine, the covers are not meant to be removed as the computer components could be easily damaged.
Husqvarna... | Answered on Oct 08, 2016
Look at the presser foot and imagine they are at the center of a clock. Now look at 4:00. There is a horizontal wheel (dial) on the free arm that needs turning.
The feed teeth are lowered when you turn the dial on the front of the free arm to the left . Turn the dial to the right if you wish to raise the feed teeth. The feed teeth will raise as you begin to sew.
Look at #12 on page 2 here: http://new.husqvarnaviking.com/sitefiles/clientsite/57/57c874e2-c4de-4acc-a703-3d47b01f941b.pdf
Husqvarna... | Answered on Feb 22, 2015
check with a1sewingmachines.com and see if they can help you with the part
Husqvarna... | Answered on Aug 08, 2014
No. That particular machine never needs oiling. That is one of the great things about a Husqvarna Vik sewing machine.
Husqvarna... | Answered on Feb 26, 2011
Hello pup...... In the future, don't wind the bobbin so fast. The reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. If you dont wind it so fast, it doesn't get so tight. Remove a few yards of thread from the bobbin and it will release from the winder peg. Joe
Thanks for choosing Fixya!
Husqvarna... | Answered on Dec 24, 2010
I don't know if this is an option for you, but you might try to take the machine to someone that specializes in these machines. It is very hard to diagnose these types of problems over the computer. But if you have someone look at it. It is possible that there is a very simple fix.
Husqvarna... | Answered on Oct 26, 2010
Hi,the solution is possible, The answer is a little bit long, so i will give you a link to get the manual on how to adjust the sewing machine.
ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf.
Take care.
Husqvarna... | Answered on Jun 06, 2010
Likely top thread tension needs to be set higher.
With the additional layers it will take a higher top thread tension so the take up lever pulls the extra top thread from bottom side through the fabric stack before it takes it from the spool.
If youre not sure whether top or bottom thread that is nesting, try a different color top thread to make determination easier.
Husqvarna Sewing... | Answered on May 24, 2020
Take the foot pedal apart and look for a return spring. Clean the inside track at the same time. You will probably find the screws hidden under the rubber feet.
Husqvarna Sewing... | Answered on May 07, 2020
WHY DO YOU NOT CALL THE PLACE YOU BOUGHT IT FROM AND GET HUFFY WITH THEM SURELY YOU HAVE WARRANTY
Husqvarna Sewing... | Answered on May 02, 2020
Thank you so much for the post. Seems like you know more than the rep at Joanns fabrics.
She did not know how to take the bulb out.
Husqvarna Sewing... | Answered on Mar 19, 2020
Raise the foot! Hours of frustration and this fixed the triple beep when trying to wind the bobbin.
Husqvarna Sewing... | Answered on Mar 02, 2020
Hi Sippe Max-
I found this owners manual link to your Husqvarna H-class 600e sewing machine.
http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/1fd5659e6f37141041256697003e64c0/150dbfd2b9107babc12578010047839a/$FILE/HClass_600E_manual_EN_A.pdf
On page 55 of the manual it talks about what ER9 means. and how to fix it.
Hope this helps.
Husqvarna Sewing... | Answered on Feb 28, 2020
I just started 6 weeks ago and I've gotten 2 check for a total of $4,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!" Visit site:: http://Neway9.com
Husqvarna Sewing... | Answered on Jan 17, 2020
Husqvarna Interlude 445 Sewing Machine Logo
12 questions posted
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Husqvarna Sewing Machines
Most Popular Question
wound bobbin now get off
  • Sewing Machines
