20 Most Recent Euro-Pro Shark 9110 Sewing Machine Questions & Answers
check and make sure the bobbin winder has returned to it's normal position for when you sew
Euro-Pro Shark... | Answered on May 10, 2016
First check that the thread in the bobbin is facinf the correct way. Then check tension on top. Also check to see if you have the same thread on top and in bobbin. Also needle and material can cause the bobbin to jump. Make siure that the needle thread stays where it should, if one of the threading sites come undone this can cause bobbin jump too.Hope something here helps.:-)
Euro-Pro Shark... | Answered on Mar 18, 2015
Check to be sure your bobbin is in correctly. so turn clockwise, others counterclockwise.
Euro-Pro Shark... | Answered on Mar 13, 2015
If you can turn the machine then I would say you probably need a new foot controller. Otherwise maybe something is caught in the machine.
Euro-Pro Shark... | Answered on Dec 23, 2014
Could be you are using the wrong needle. If it is too short it will not pick up the bobbin thread. Or your machine could be out of time.
Euro-Pro Shark... | Answered on Nov 04, 2014
Slide of the the little table with the accessories in.There is a feed dog adjustment lever at the back of the machine. sliding the lever to the 2 filled in arrows pointing down, will lower them and the 2 filled in arrows pointing up will raise them. The feed dogs will not rise up if you do not turn the hand wheel manually, even if the lever is slid to the right.You must make a complete turn of the wheel to raise the feed dogs.
Best wishes.
Euro-Pro Shark... | Answered on Jun 30, 2014
I have had problems with this too. But you can get them from Euro Pro about $10.00
Euro-Pro Shark... | Answered on Jan 23, 2014
There is a screw that holdsthe linkage together that rotates the bobbin holder, that screw might beloose. To replace it requires taking both the front and back covers off of theframe since the bobbin holder linkage is in the rear behind the needle area. Becareful to insure that the plastic toothed "rail" that runs thebobbin holder is positioned properly or it may break off a tooth. Once you replace it, it will catch the threadagain. AV
Euro-Pro Shark... | Answered on Sep 04, 2013
check to make sure the foot pedal is plugged into the machine correctly
also the foot pedal may need to be checked at a sewing machine repair shop to see if there is something wrong with the wiring or electronics.
Euro-Pro Shark... | Answered on Jul 12, 2013
Como puedo programar mi maquina
Euro-Pro Shark... | Answered on May 31, 2013
Euro-Pro Shark 9110 Sewing Machine Logo
65 questions posted
Top Euro-Pro Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Euro-Pro Sewing Machines
Most Popular Question
mi maquina de coser no da puntadas
  • Sewing Machines
