20 Most Recent Singer Confidence 7463 Computerized Sewing Machine Questions & Answers
I now have a machine with no cases. The first one to come off was the front one. The process was as follows: Remove the end plastic bit the cap over the foot. Undo all screws you can get to Unser the end cover (previously removed) there is a single screw with washer holding the front cover. Unscrew this ine. Then it takes a bit of jiggery pokery to separate all the plastic tabs. I used a wide bladed screwdriver and the two halves just split. The front half is then disconnected from the Circuit board and you are nearly there Then lift the machine from the rear casing, again it moght be necessary to jiggle quite a bit. Goog luck.
Singer... • Answered on Feb 19, 2019
sounds like the mother board, or software issue? it will need to be serviced
Singer... • Answered on May 19, 2018
Try straight stitching on the left side and then on the right side of the foot. If it doesn't give a stitch on the left it is a sure sign that it needs to be timed.
Singer... • Answered on Dec 21, 2017
Check manual for proper threading and insertion/orientation of needle. Or...needle damaged.
Singer... • Answered on Dec 17, 2016
If you are talking about being able to move the fabric freely with your hand, you need to drop the feed dogs and install a darning foot. The darning foot is just a smidgen shorter than the standard presser foot so it does not rest on the feed dogs or the needleplate. The extra space allows you to manipulate the fabric without feed dogs. ...
Singer... • Answered on Jan 17, 2016
I need a bit more information. Was the machine working correctly before this happened? Have you checked that the threading sequence is correct and nothing is blocking the path? Is the bobbin seated and threaded correctly? Are the feed dogs clear of fluff?
Singer... • Answered on Dec 31, 2015
sounds like it's set to a different function than what you're wanting at the time, perhaps reset, check the needle's position (mine wouldnt work because it was still in threading position)...or you have it's function set at the innappropriate speed (see panel on machine)...really dont know without seeing it, but it happened to me too once, just had to fiddle with it's speed and settings til it allowed what i was wanting to do. If you need further help, I’m available over the phone at https://www.6ya.com/expert/dakota_dc0ddcb0159cca1c
Singer... • Answered on Nov 27, 2015
Consult your owner's manual and verify that you are inserting the needle properly (which way the flat side faces when in your machine) and that you using the correct needle for your machine. ...
Singer... • Answered on Oct 05, 2015
The foot pedal is just a variable resistor to give you speed control of the motor You say the machine is new so it will still be under warranty have a service technician check it out It could be a faulty control pedal or leads or motor
Singer... • Answered on Aug 05, 2015
You can buy a replacement at Sewing Parts Online, and here's a direct link to the part. It costs $15.00 Needle Plate Singer 051099
Singer... • Answered on Jul 02, 2015
tryrethreading the machine top & bobbinclean under the needle plate & in the bobbin area for lint or threadmake sure bobbin is inserted correctly & that it's not damagedtry changing the needle
Singer... • Answered on Jun 17, 2015
1. Adjust the bobbin tension tighter. The tension you are trying for is to be equal to the top tension. 2. The top tension should start at about four. When you are threading the top do it with the pressure foot up. 3. As you are threading the top give little tugs to check for snags. 4. When you thread the tension control make sure it goes through the tension disc. 5. After you have threaded (except needle) lower the pressure foot. 6. Give a tug to see if the thread will move without excessive resistance. 7. Thread the needle and try sewing.
Singer... • Answered on Mar 10, 2015
Check your manual for some troubleshooting tips. Something is not plugged in, or seated right, like the bobbin. Here is a sequence of (comments) problems that others have had with this machine. http://www.erinsayssew.com/singer-confidence-7463-sewing-machine-review/
Singer... • Answered on Feb 28, 2015
I found the instruction manual for the Confidence 7465 on Singer's web site available for download. This should be in there. The URL is: http://www.singerco.com/products/1497/7465-confidence#type-resources
Singer... • Answered on Feb 14, 2015
Yes, you need to review the steps to sew a button hole, because just putting on the foot is not enough. Generally there are several other things that must be set before it will actually sew buttonholes. Download your user's manual free at the Singer Sewing machine website, and review it.
Singer... • Answered on Dec 20, 2014
Just on the inside and slightly below the hand wheel, there is a round motor, and to the left of that there is a cam that controls the feed dogs. One of these (most likely the cam) is stuck, and that's why it only sews in reverse for a short time. You might try manipulating the feed dogs manual to see if you can unstick it, but most likely you will need to get the machine serviced by a technician to fix it.
Singer... • Answered on Nov 29, 2014
Singer Confidence 7463 Computerized Sewing Machine Logo
94 questions posted
Top Singer Sewing Machines Experts
dannydoesita
Michael Thomas
Michael Thomas
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
needle wout go into needle shaft boddin
  • Sewing Machines
