20 Most Recent Philips HD4671 Electric Kettle Questions & Answers
One of the lid springs
The Philips HD4671 lid springs also tend to break after a short while, and often just after the waranty has finished. Philips do not sell replacement springs.I made my own by using .65 mm V shaped spring using stainless steel wire and winding it round a 4 mm diameter nail a couple of times. I left the tail ends about 25 mm long and formed the ends at right angles. I then drilled two small holes in the plastic hinge assembly and then located the ends of the spring through the two holes to secure it in place.The end result was better than the original part and it only cost me 80 pence plus postage for the wire.
11/17/2016 9:03:09 AM • Philips HD4671... • Answered on Nov 17, 2016
0answers
Need new base
Try http://www.support.philips.com/support/service/onlineStore.jsp?userCountry=us&userLanguage=en
At the top corner you can choose your country, and hopefully you'll be able to locate a local Service Center
5/19/2010 9:02:56 AM • Philips HD4671... • Answered on May 19, 2010
Kettle Philips type hd 4686 leak
If the leak is under the kettle just replace it with a new one. Water and electricity are a DANGEROUS mixture. There is a VERY high risk of electrocution and of fire if you keep using this kettle. New ones are usually cheap enough for a basic kettle.
9/13/2022 12:09:51 PM • Philips Kitchen... • Answered on Sep 13, 2022
Looking for the manual for the Philips KB1100 food sealer.
Contact Philips directly to inquire about the manual.
11/12/2020 8:31:32 PM • Philips Kitchen... • Answered on Nov 12, 2020
I'm looking for a measuring cup for Philips egg boiler he/4351/d?
Hi there, if you go to eBay, and type in the details you have here, you will be able to find what you're looking for, good luck
4/23/2019 4:14:00 PM • Philips Kitchen... • Answered on Apr 23, 2019
Philips air fryer fan not working?
There could be several reasons for fan not satrting. 1. Check the thermal fuse, if blown replace it 2. Check the timer which could need replacement 3. Finally, it could be the motor of fan itself.
1/8/2019 7:44:50 PM • Philips Kitchen... • Answered on Jan 08, 2019
3answers
How can i use my reward points earned in sbi
Hi, they explain it on their website: https://www.sbicard.com/creditcards/faces/pages/CreditCardRewards.jsp
Redeeming Power PointsWith the Shop & Smile Rewards programme every time you use your SBI Card you get Power Points. These Power Points can be redeemed for exciting rewards. Here is how you can get them:
Check your latest Card statement to see if you have accumulated a minimum of 1000 points.
Call the SBI Card helpline 39020202, if calling from BSNL/MTNL line dial 1860 180 1290 | 1800 180 1290 OR
write to us at PO Box 28, GPO, New Delhi- 110001
We will have your gifts delivered at your doorstep!
11/21/2018 2:55:53 AM • Philips Kitchen... • Answered on Nov 21, 2018
Need a manual for a 1060 philips bread machine
Manualsonline.com or manufacturer
11/2/2017 6:27:12 PM • Philips Kitchen... • Answered on Nov 02, 2017
0answers
I am trying to find the nearest place Where I can take my faulty all in one Philips cooker
Look for small appliance repair outfit in your locale.
9/19/2017 2:17:51 PM • Philips Kitchen... • Answered on Sep 19, 2017
Philips HD4671 Electric Kettle Logo
8 questions posted
Top Philips Kitchen Appliances - Others Experts
Thomas Perkins
Thomas Perkins
ray gallant
Kardoc
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Kitchen Appliances - Others
Most Popular Question
one lid springs
  • Kitchen Appliances - Others
