? 4:30
https://www.youtube.com/watch?v=_yWSU0kTkTg
Mar 20, 2013 - Uploaded by Joe Devlin
When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
? 9:23
https://www.youtube.com/watch?v=YubSrHE7WFc
Dec 7, 2012 - Uploaded by eric hatch
I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
? 1:33
https://www.youtube.com/watch?v=oPQE2oLTR3o
Jan 26, 2014 - Uploaded by jjthetechguy
I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
The fuse is probably open, when this happens it usually indicates a secondary problem from a defective door switch, keypad control board failure to a inverter board issue.
This is an error on the main control board. Remove the power and remove the top cover. Do not touch any capacitors within but try and remove the main board. check if there is any insect secretion , if so wash and reset. If the fault repeats then it is possible that the motherboard is a suspect.
has a blown inner fuse or a open thermo (under the oven cavity ceiling or on the magnetron). if it's the main fuse out, you probably have a failed component.
Judging from reviews of this model on Samsung's website, this is a common problem. Does it happen during or after using the cooktop or range below the microwave oven? In particular, is it most common when using the burner directly under the microwave oven control panel?
If the issues are correlated to heat or humidity from cooking on the range top, I would suspect problems with moisture in the keypad circuitry. I would consider cleaning the controller board key panel connector area with 90%+ isopropyl alcohol (this is an internal service on a circuit board that is most likely susceptible to damage by static electricity, so it should be done by someone who knows how to service electronics). This should remove contaminants that could cause current leakage between keypad connections (spurious keypad entries) in humid conditions. Let the board dry thoroughly before reconnecting.
It's also possible that moisture is getting into the keypad assembly. This would be a design/manufacturing flaw. I would guess the oven is out of warranty, so the fix would be to put the keypad in a dessicator for a day or so, then seal the edges with RTV Blue or a similar caulk that does not release acetic acid (vinegar) during the curing process. (Acetic acid even in vapor form may corrode the silver contact material in the keypad.) Do not seal the connector, just the edges of the flex ribbon layers where moisture can get into the key membranes.
In the meantime, always use the microwave oven fan when cooking on the range. This will help to keep the controller cool and dry. (Samsung's troubleshooting guide says the fan will turn on automatically if the microwave oven gets too warm from cooking underneath it.)
It sounds like you are having difficulty with the bottom switch on your Samsung Model GE0103MB microwave not engaging with the door release button. This can prevent the microwave from functioning properly and could be caused by a few different issues:
Make sure that the switch is properly connected to the door release button. The switch may have been installed incorrectly during the repair process, which could prevent it from engaging properly.
Check the door release button to ensure that it is not damaged or malfunctioning. The door release button could be preventing the switch from engaging properly.
Check the wiring connections to the switch and door release button to ensure that they are secure and not damaged.
If you are having difficulty assembling the microwave, I suggest you to try and get the service manual or a diagram of the assembly process for your specific model GE0103MB. You can try searching for it online or contacting Samsung customer service, as they may be able to provide you with the information you need.
If the problem persists, you may want to contact a qualified technician to service the microwave and inspect the door switch and door release button.
It's important to note that working on a microwave oven can be dangerous and should only be attempted by someone who is familiar with the inner workings of the device, and have the proper tools and equipment.
It will be fine. They aren't made for sustained cooking on high power. Popcorn is dry but oiled, so it gets very hot and burns. You can use the glass carousel plate or replace it. Depending how big the crack is, any water in the crack will finish it off. A new glass tray is $57. A new Microwave the same is $319. Samsung are one of the better makes.
https://www.google.com/search?q=samsung+me18h704sfs+replacement+glass+plate
