20 Most Recent Samsung SMH9151 Microwave Oven Questions & Answers
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove. Or you can watch a YouTube video (not a video I made) that demonstrates how it's done. In some cases, you then have to gently rotate the handle to unlock it. You can find helpful exploded view diagrams and order parts by entering your full model number here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer. 25060245-2eaufixstlx223aid0wpxsf5-4-0.jpg
Samsung SMH9151... • Answered on May 23, 2016
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm See my profile picture if you need more help.
You have 2 systems inside your microwave, one is working, one is not. The working one has the electric motor to drive the turntable and the timer. The other system includes the "magnetron", which is the heavy unit that makes the microwaves to cook the food. A repairman can check the magnetron to see if it has failed, and there are a few units that have a replaceable fuse that could be blown. You will not want to try to fix it yourself, without a good knowledge of such things, as there is often a capacitor inside, which can shock you really bad if you touch it in error. God bless your efforts.
Samsung SMH9151... • Answered on May 03, 2016
"SE" error means you have a shorted membrane keypad.
The exact part you need will depend on the model number, which will be one of these:
SMH9151B SMH9151B/XAA SMH9151B/XAC SMH9151BE SMH9151BE/XAA SMH9151S SMH9151S/XAA SMH9151ST SMH9151ST/XAA SMH9151ST/XAC SMH9151STE SMH9151STE/XAA SMH9151W SMH9151W/XAA SMH9151W/XAC SMH9151WE SMH9151WE/XAA.
On some models, you can just order a new membrane keypad and replace it. It's cheap, but a lot of work.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On other models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job, but it costs more.
Feel free to contact me directly (and please remind me of your full model number) for more information & help and a free estimate for us to do it for you.
Samsung SMH9151... • Answered on Dec 19, 2014
Probably the control panel has a problem like a poor connection or faulty touch pad.
Samsung SMH9151... • Answered on Jun 17, 2014
Please inspect the plastic latches that should actuate the door switches. Sounds like you may have broken one when slamming the door too hard
Samsung SMH9151... • Answered on May 06, 2014
some time due to moisture the membrane switch stops working - which can't be repaired - the only solution is to replase it.
Samsung SMH9151... • Answered on Mar 05, 2014
This is actually a simple DIY job. The service manual is at my site here. You simply move your circuit board into a new control panel frame assembly, which comes with a new keypad already attached. For model SMH9151S, it is part number DE94-01806K ("Assy Control PANEL") and you can order it from the Pros here for about $42. If it is not in stock when you order, they can have it to you in just a few days. You can also find helpful exploded view diagrams and order other parts via that link. There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes. If you have trouble, slide the hood vent grille to the left about 1/4", then then pull it forward. Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame. Be careful, since the display is made of glass. fetch.cgi?redirect=http%3a%2f%2f031d26d.namesecurehost.com%2fmwd%2fkeypad_connector.jpg Some connectors on the relays have a lock:
Samsung SMH9151... • Answered on Jan 20, 2014
The service manual for model SMH9151B is here. You can order Samsung parts by part number from the Pros here. <- Let me know if I can help further.
The SE error indicates a short in the key panel. You can try resetting the microwave by unplugging it (or turning off the circuit breaker). Leave it off for a minute or so. If the code recurs, check if the microwave is under warranty. If it is still covered by the warranty, contact Samsung for repairs. If it is out of warranty, decide if it is worth sending the microwave in for repairs. (You'll have to pay a fee for diagnosing the problem; that will be applied to the actual repairs if you have the unit fixed.) I hope this helps. Cindy Wells
Samsung SMH9151... • Answered on Sep 06, 2013
Samsung SMH9151 Microwave Oven Logo
84 questions posted
Top Samsung Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
se or 5e display samsung model number
  • Microwave Ovens
