20 Most Recent LG LRM2060ST Microwave Oven Questions & Answers
Take turntable motor off and examine teeth on it and on gear it turns. Access is from bottom of microwave
LG LRM2060ST... | Answered on Nov 30, 2014
I would not recommend you to try & fix this yourself. Microwave ovens can hold a very high electrical charge even when unplugged which makes them dangerous to work on if you are not qualified to to so. The door latch will need to be adjusted from inside the unit & then must be tested to ensure there is no microwave leakage from the door seal to ensure it is safe to use. Take the oven to a recommended repair service centre.
LG LRM2060ST... | Answered on Nov 18, 2013
if u know whats wrong how can i help
LG LRM2060ST... | Answered on Apr 01, 2013
grill chicken wing methed
LG LRM2060ST... | Answered on Sep 20, 2012
the problem could be with 2 component. The diode or the magnetron. normally when the diode goes bad, the microwave will make a humming sound. The microwave will tend to sound almost normal when its the magnetron. Or sometimes it will make a sparking noise when put to heat.
LG LRM2060ST... | Answered on Feb 27, 2011
They will use exactly what they state on the identity label on the rear of the product. If they are all rated at 1200Watts, then that is what they will use per hour.
LG LRM2060ST... | Answered on Feb 10, 2011
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
LG LRM2060ST... | Answered on Jan 29, 2011
The fuse is located inside.
LG Microwave... | Answered on Jan 06, 2021
THE HIGH VOLTAGE FUSE IS IN A PLASTIC EXTRUSION NEXT TO THE CAPACITOR AND DIODE.
YOU CAN USE 3 OR 4 STRANDS OF THIN WIRE FROM MULTI STRAND 15A MAINS CABLE. SOLDER IT OVER THE BLOWN FUSE. I HAVE DONE THIS 100'S OF TIMES.
LG Microwave... | Answered on May 18, 2020
It's most likely your door switch. I have the same problem and was told that. I'm not 100% certain, but will take a look at mine and let you know.
LG Microwave... | Answered on Oct 22, 2019
What is it that you are losing ? You can set the power level by using the marked touchpads on the touchpanel, much like setting the volume on a TV. If you do not change the power setting and it is taking a long time to heat things or intermittently fails to, that is usually a sign that the Magnetron has reached its use by date and needs to be replaced. Not always an economical proposition unfortunately as spare parts are often exorbitantly priced.
Before removing the cover of the oven in attempt to carry out any maintenance such as replacing the Oven cavity lamp, make sure the oven is disconnected from the power point ! The voltages in a microwave oven ARE LETHAL !
LG Microwave... | Answered on Oct 18, 2019
LG LRM2060ST Microwave Oven Logo
22 questions posted
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
blown thermal fuse
  • Microwave Ovens
