20 Most Recent
Rowenta DZ2010 Iron Questions & Answers
How to remove cord on Rowenta DZ2061
Your iron probably has tamper proof outer screws with a center pin...don't be intimidated. First, try to remove the screws with a tiny screwdriver from an eyeglass repair kit. If that doesn't work, get a Torx T-20
nutdriver attachment. If you have to replace the cord, here's a possible supplier:
Smallappliance.com
How do you fix a seal on a Rowenta Iron?
To try and seal the water leak will possibly render the appliance dangerous.
I would speak to Rowenta and ask the question. They may well extend the warranty if you suggest it wasn't used for say a few weeks after purchase etc.
How to fix water leaking out of bottom of Rowenta steam iron
I'm on my fifth Rowenta iron. The first four eventually started to leak. I keep buying Rowenta because I get the best results except for the leaking. I've been using filtered water even though the manual sas to use tap water. I will start o use tap water. The fifth one I bought was highly rated by Consumer Reports. If this new one starts to leak, I'll bring it back and buy a different brand.
How to descale Rowenta model 9250
Pour in some vinegar (half) and some water (half) in the machine. Turn it on and let it run a bit. Make sure to do it outside since it smells badly. After that, rinse a few times before use.
