20 Most Recent Rowenta DW9080 Iron with Auto Shutoff Questions & Answers
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Rowenta DW9080... | Answered on Aug 22, 2011
The wire is already damage specially the other end that goes trough the iron try to replace the wire or you can trace the damage wire using a continuity tester then cut the damage wire then try to connect the other half it is usually screwed in the heating element. The leaking part of the iron below the face plate you can use a silicon adhesive to cover the leak. Good day and best regards.
Rowenta DW9080... | Answered on Jul 18, 2011
Contact Rowenta to request an assembly diagram, then follow it in reverse.
Rowenta Irons | Answered on Jul 29, 2020
I think there's no fuse in this steam iron. If the iron does not work, the thermostat or the power cord may be damaged.
Rowenta Irons | Answered on Dec 02, 2019
Possible heating element or control circuit failure
Rowenta Irons | Answered on Dec 01, 2019
Request the diagram/photo directly from Rowenta.
They are built to shut off after about 30 sec or so if the iron is not moving and the iron is in pressing position (sole plate down). They shut off if they are not moving and standing with the sole plate vertical, in about 5 minutes. If you move the iron (like ironing) they reheat. If it doing something else the electronic control is defective. It is cheaper to replace than repair.
Rowenta Irons | Answered on Nov 03, 2019
Contact Rowenta directly to inquire.
Rowenta Irons | Answered on Oct 28, 2019
Rowenta DW9080 Iron with Auto Shutoff Logo
14 questions posted
Top Rowenta Irons Experts
Ekse
Bruce Showalter
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
View Most Popular
Rowenta Irons
  • Rowenta Irons
Most Popular Question
clean
  • Irons
