20 Most Recent
Magimix 3200 Food Processor Questions & Answers
Motor humming but drive shaft not moving
I would suspect either the starting capacitor on the motor or worst case the motor itself. The capacitors are a fairly common item to fail while the motors are uncommon. Expect a new motor to be extremely expensive.
Is it possible to get
Dear Customer,
Please download the English manual for Magimix 3200 Stainless Steel Food Processor from below :
http://www.magimix.fr/download.php?dwn=download_usa.pdf&path=upload%2Fnotice_d_utilisation%2Fma_cuisine%2Fdownload_usa.pdf
I have a model close to the 3200 - it is the
That handle is actually press fit type handle.The handle needs to be matched the bowls body, then slightly lifted and pressed.But if its not getting attached or still getting loose, or not fitting that way, then sticking that handle is another option.But actually its not glued handle, its press fit type handle.------
But if its not fitting by that way, then glue it, and let it remain untouched for 3 to 4 hours after glue is applied.Then after few hours, you can use it.It will get hard/permanent.-------
This will help.Thanks.Helpmech.
Hi my magimix 320xl won’t turn on the Handel clicks in ok so I’m not sure what the problem is it’s only been used a couple of times hope you can help me thank you Christine
If your Magimix food processor won't turn on despite the handle clicking in, there may be a problem with the power supply or the motor of the device. Here are a few troubleshooting steps you can try:
- Check that the power cord is securely plugged into an outlet and the processor's base.
- Make sure the outlet is working by plugging in another device.
- If the outlet is fine, then try plugging the Magimix into a different outlet.
- If the device still doesn't turn on, it's possible that the motor has overheated. Allow the device to cool down for a few hours and try turning it on again.
- If none of these steps work, you may need to contact the manufacturer or a repair technician for further assistance.
It's also worth noting that the Magimix 3200XL comes with a 30-year motor guarantee, so if the motor is the problem and the device is still under warranty, you may be eligible for a replacement.
