20 Most Recent
Magimix 3100 1057 Cups Food Processor Questions & Answers
How to clean the handle of a Magimix
The handle of a magi mix cannot be removed. This is how you can clean the muck out of the handle.
There are two openings at the top of the handle. One next to the bowl and the other is at the top of the handle grip. Pour dishwashing liquid (as much as possible) into the two openings. You will see it flowing into the handle.
Then you will need a 'K'archer (or similar) water blaster. Direct the jet into the two openings. This should be done with the jet almost in contact with the handle to achieve maximum pressure. The dirt will start to come out. Repeat this cleaning operation with the dishwashing liquid and water jet (perhaps 5 times) until the handle interior is clean. There are 4 small drain holes on the sides of the handle into which dish washing liquid can be poured and jetted out.
I know this method works, as I have done it successfully on my wife's Magimix!
Des Pollard
Cape Town, South Africa. 12 March 2019
The handle of a magi mix cannot be removed. This how you can clean the muck out of the handle.
Des Pollard
Hi my magimix 320xl won’t turn on the Handel clicks in ok so I’m not sure what the problem is it’s only been used a couple of times hope you can help me thank you Christine
If your Magimix food processor won't turn on despite the handle clicking in, there may be a problem with the power supply or the motor of the device. Here are a few troubleshooting steps you can try:
- Check that the power cord is securely plugged into an outlet and the processor's base.
- Make sure the outlet is working by plugging in another device.
- If the outlet is fine, then try plugging the Magimix into a different outlet.
- If the device still doesn't turn on, it's possible that the motor has overheated. Allow the device to cool down for a few hours and try turning it on again.
- If none of these steps work, you may need to contact the manufacturer or a repair technician for further assistance.
It's also worth noting that the Magimix 3200XL comes with a 30-year motor guarantee, so if the motor is the problem and the device is still under warranty, you may be eligible for a replacement.
How do I remove the blade unit from Magimix cuisine 5100?
Firstly, press the STOP button. Then turn the lid in a clockwise direction and lift-off. Carefully remove the blade and inner bowl/bowls (depending on what combination you are using). Finally turn the main bowl clockwise to unlock it from the motor unit and lift off.
