20 Most Recent
Wells F14 Deep Fryer Questions & Answers
How many amps does the
For a 120V 1-phase unit:
15 amps; 1.8 kilowatts
For a 288/ 240V, 1-phase unit:
16.4amps/ 18.8amps; 3.4/ 4.5 kilowatts
You can download owner's manual at http://www.wellsbloomfield.com for your reference.
Regards.
Trouble light comes on, can barely read the
When trouble light comes on, it indicates that the hi-limit is tripped (this happens when oil temperature exceeds 450 Fahrenheit). The red button is located at the upper back panel of the unit, give it a push to reset but if nothing happens after resetting the button, the hi-limit needs to be replaced. Also try to check if the thermostat is working, stuck thermostat's mechanical contact will cause the hi-limit to trip.
Wells electric fryer model f-67 wont reset
Hi there! If hi limit wont reset when button is pushed, there might be a mechanical problem inside the part which prevents t from resetting, you have to replace the part.Visit www.middleby.com and select wells to find the nearest authorized parts dealer near your area.Regards.
Hi I believe I have
Running the fryer with no oil will over heat the coil very quickly...this caused the element to burn out...
That element will be replaceable...
If you call these guys you should be able to purchase a new element from them...
http://www.fryerworld.com/wells-f49.html
heatman101
