20 Most Recent
La Pavoni CUA001R Cuadra Espresso Machine Questions & Answers
When pulling coffee by opening
in the system you have 2 safety valves. one for tank other for coffee boiler. the coffee boiler safety valve should be set at 12 bar.
if safety valve of boiler is leaking try resetting or changing rubber than setting.
ps: do not touch the tank safety valve, only change it with new, tested and sealed one.
2/12/2011 2:35:35 PM •
La Pavoni...
Answered
on Feb 12, 2011
La pavoni slow water flow
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
What causes my la pavoni europicola to make a whistling when it;s turned on?
hi
it is normal when water heating up and pressure begin to be built in the boiler until the vacuum braker at the safety valve close
but if it continue to whistle when the green light goes off
after few minutes it means you have too much pressure in the boiler and it is realesed through the safety valve
in that case you have to replace your pressurestat or you have scale at the bottom of boiler in the entrance of the pipe leading to the pressurestat
regards
Guy
Coil sealant
HI you shouldn't use sealant. if the silicon seals are broken they should be replace, they are available from sellers on ebay.
Hi what size tamper do i need for la pavoni ebr machine about 12 yrs old thanks
Hi I have one of these in the attic, they do not come with a tamper as they have a fancy pressurised portafilter , its good to level the coffee and if I remember I did used to give it a bit of a tamp as it just didn't seem right not to. I have found a couple of references to tamper size on the web and both say 53mm I can't totally vouch for this though, you can always check with a ruler.
Where can I find a user manual for la pavoni ubar V3
Hi I have had a search using the info you have given but I can't find a reference to a UBAR I have put a link to pavonis site which leads to the specifications for some of their BAR products. Their website is a bit unhelpful but if you search on their site for PDF you may be able to find what you need. I used a add on for firefox that searches within the site you on for any word you have in the search box rather that looking on the whole web. from this you might be able to work out the model you have.
http://www.lapavoni.com/PDF/CAT_BAR.pdf
