20 Most Recent
Nespresso Citizmilk C120 Questions & Answers
The milk deposit do not work
MILK FROTHER HAS TO BE CHANGED IF YOU DONT HAVE ANY POWER THEN CHANGE POWER TO FROTHER IS DIRECT SOW THERE IS NOTHING TO CHANGE
3/15/2016 2:47:45 PM •
Nespresso...
Answered
on Mar 15, 2016
The milk in the frother
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
1/6/2015 6:16:00 AM •
Nespresso...
Answered
on Jan 06, 2015
My Nesspresso machine is a
I don't know if you already solved the problem, but did you check what the maximum output power of your aircraft is? The nespresso machine needs about 1250 Watts, which is a lot of power. A vacuum cleaner or microwave use less power than that (maybe between 800 - 1000 Watts). Maybe that difference is the reason. Also, you mentioned that you converted from 220V 50Hz to 120V 60Hz. I think you only converted the voltage, a frequency converter would cost thousands of dollars.
12/13/2013 4:09:18 PM •
Nespresso...
Answered
on Dec 13, 2013
I only purchased my Nespresso
It seems like somehow the machine is reprogrammed. First holddown the push button for 3 secs you get 3 secs of coffee, so turn on yourmachine wait for it to temperate up then without using a capsule press and holdthe button until you get 110mls for a lungo and this will be stored in thememory. If this doesn't work there is an on/off switch on the right hand sideturn it on with your finger down on the lungo button for 5 secs and then dischargethe button and this will take it back to factory settings.
5/3/2011 3:33:28 AM •
Nespresso...
Answered
on May 03, 2011
Nespresso Pro ES 80 descaling guide needed.Can Tim Grayson help me on getting again the PDF ?
I can guide you through the descaling process for your Nespresso Pro ES 80 machine
1. Set up a descaling arrangement: Buy a descaling arrangement reasonable for Nespresso machines. Adhere to the guidelines on the descaling arrangement bundling and blend it in with water as per the suggested proportion.
2. Void Water Tank: Guarantee that the water tank is vacant and eliminate any pre-owned containers from the machine.
3. Begin Descaling Mode: Spot a compartment under the espresso outlet to get the descaling arrangement. Press and hold the "Power" button, and afterward press the "Power" button to begin the descaling mode. The lights will begin blazing.
4. Descaling Cycle: Empty the descaling arrangement into the water tank. Press the "Power" button to begin the descaling system. The arrangement will move through the machine and into the compartment. Permit the answer to stream until the tank is vacant.
5. Wash: When the descaling system is finished, flush the water tank completely and fill it with new water.
6. Flush: Press the "Power"" button to run new water through the machine and wash out any excess descaling arrangement. .
7. Last Wash: Top off the water tank with new water and run one more pattern of new water through the machine to guarantee all hints of descaling arrangements are flushed out.
8. Finish: Your Nespresso Expert ES 80 machine is presently descaled and prepared for use.
Assuming that you actually require the particular PDF guide, I prescribe contacting Nespresso client care or looking for the manual on their authority site.
Hi, My Nespresso handle is stuck in the open / up position and there is no capsule or tray inserted, open & empty. Advice please
Which model of machine is it? How old is it? Is it plugged into the wall socket and turned on? Some newer Nespresso machines need a power supply to turn on and to work.
Next check the drop bin the used pods drop into. Sometimes when it is full a pod won't drop properly and can jam the mechanism.
Try this. When the machine is Cold and unplugged from the wall. Remove the drop bin. Swing the handle to the fully open position and carefully feel Up from inside the hole the drop bin sits in. Your checking to see if there's a pod jammed in there.
If it still won't close it could be a broken part from inside the machine jamming the sliding rails. The finger test above might knock the broken piece loose.
Nespresso D150 coffee makes leaking water tank
If your Nespresso D150 coffee maker is leaking water from the bottom as soon as you attach the water tank, there might be a few possible causes for this issue. Here are some steps you can take to troubleshoot and address the problem:
1. **Check O-Ring Seal:** Even if the O-ring inside the water tank appears fine, it's worth inspecting it closely for any signs of wear, damage, or misalignment. If the O-ring is not creating a proper seal, it can lead to leaks.
2. **Clean and Lubricate O-Ring:** Sometimes, debris or residue can accumulate on the O-ring, preventing it from forming a tight seal. Clean the O-ring and the area where it sits in the water tank thoroughly. Applying a small amount of food-grade lubricant can help ensure a proper seal.
3. **Check for Cracks:** Examine the water tank for any cracks or damage that could be causing water to leak out. Even a small crack can lead to significant leakage.
4. **Check Water Tank Connections:** Ensure that the water tank is properly aligned and securely attached to the machine. If it's not properly seated, it can cause leaks.
5. **Inspect Machine Gaskets:** There might be gaskets or seals on the machine itself that interact with the water tank. Inspect these gaskets for wear, damage, or misalignment.
6. **Water Level Sensor:** Some coffee makers have a water level sensor that detects the water level in the tank. If the sensor is damaged or not functioning correctly, it might cause leakage. Contact Nespresso or a professional technician for assistance with sensor-related issues.
7. **Pressure Relief Valve:** Coffee makers often have pressure relief valves to regulate pressure within the system. If this valve is not functioning properly, it can cause leaks. This might require professional assessment and repair.
8. **Contact Customer Support:** If the issue persists despite troubleshooting, consider reaching out to Nespresso's customer support or a professional technician who specializes in coffee maker repairs. They can provide more specific guidance based on your machine's model and issue.
Remember that working with electrical appliances and water can be potentially hazardous. If you're unsure about any aspect of troubleshooting or repair, it's best to seek professional assistance to avoid causing further damage or compromising safety.
My Nespresso machine leaks water and hisses like a kettle after pouring the coffee.
It is possible that your Nespresso machine is experiencing a malfunction and may need to be serviced. The leak and hissing sound could be signs of a clogged brewing head, a damaged water tank or pump, or a malfunctioning valve. To prevent further damage, it is best to stop using the machine and contact Nespresso customer service for assistance. They can guide you through the troubleshooting process and provide you with options for repair or replacement if necessary.
My nespresso stops half way though making a cup of coffee and have to press the button again repeatly to start it again
Has anyone operated your machine that was unfamiliar with the correct method. It sound as though the quantity has been reset. Try holding both buttons down while turning the machine on - hold till buttons stop flashing. This will reset to factory settings. Then, you can programme each button by holding it down whilst extracting, then releasing when the correct amount is extracted. It will remember this until you return the machine to its factory settings as above.
Hope this helps!
