20 Most Recent Jura Capresso Capresso IMPRESSA C9 One Touch Automatic Coffee Center 2Cup Coffee Maker Questions & Answers
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
Jura Capresso... | Answered on May 15, 2011
Under the rotary switch on the left there is a micro
switch which is probably stuck in and it always pressed. That is why you enter
in RINCE directly and also it repeatedly stays at RINCE position.
So first you need to check the rotary switch and try
to slightly pull it out with a thin screwdriver very softly. If this it does
not make any different you need to replace this rotary switch
Are you telling the machine that you are using the funnel and not the grinder ?
You MUST press the top left hand button on the hidden keypad so the machine does NOT grind.
Also 2 level spoons (of the jura spoon) is max you can put in the funnel.
Please dont forget to vote this answer was helpful.
Many thanks
Jura Capresso... | Answered on Feb 22, 2011
This is their Direct line for Jura brand,
Good luck.
800-767-3554 Monday -Friday 9AM to 9PM and Saturday 9AM to 5PM Eastern Standard Time or email them at [email protected].
Jura Capresso... | Answered on Jan 12, 2011
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
Jura Capresso... | Answered on Dec 22, 2010
Jura Capresso Capresso IMPRESSA C9 One Touch Automatic Coffee Center 2Cup Coffee Maker Logo
18 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
jura c9 out
  • Coffee Makers & Espresso Machines
