20 Most Recent Krups Xp5240 Perfect Tamp Xp5240 Espresso Machine Questions & Answers
How to disassemble espresso machine.My gasket leaks
i think its not a gasket problem may be broken pipe or broken thermal block if you have a broken pipe it is due to not cleaning the filters you get an over pressure on the internal pipes and bingo water come out be wear of electric
3/9/2016 12:46:30 PM • Krups Xp5240... • Answered on Mar 09, 2016
I have a Krups Espresso
My XP5240 also started blowing the steamer wand off after about 3 months of use, despite fiollowing the Krups cleaning instructions. Here's what I did to fix it.A: The Problems. The wand has three holes in the coffee end (center, and on each side). The center hole gets blocked with milk residue. This causes a pressure build up in the wand assembly, and eventually this is enough pressure to overcome the three gripping clips that hold the wand to the nozzle tube. I suspect this was an intentional design for safety. It's unfortunate that it also sprays the user with milk when it lets go.The second problem is that removing the wand requires that the outer clip retainer ring to be slid down to release the clips. Many users don't realize this and try to pry or twist the wand off. This breaks the clips.B: The SolutionThe wand has to be regularly and throughly cleaned. Just soaking it is not enough. Do it this way:1. Slide the clip retainer ring down, and then hold the steam tube and gently move the wand straight down. DO NOT try to twist the wand to one side, or you WILL break the clips.2. Holding the ring, unscrew the coffee nozzle end. The wand separates into three parts: Outer tube, inner steam tube and decorative cylinder.3. Use a needle or very fine wire (approx 0.4mm) to clear the three holes in the coffee end nozzle.4. You now need to clear the metal wand tube of milk residue. I found that a 7/64" drill bit was perfect to do this, as it fits snugly in the tube. The amount of gunk removed was surprising. 5. Blow the tube clear from both ends. If it's clean, you will be able to see light through all three holes. If not, go back to step #3.6. Make sure that there is no milk residue on the steamer tube nozzle where the wand clips on. Milk contains fat, and this is an unwanted lubricant.After cleaning, my steamer works properly for several days. I also located a 21mm ID O-ring at the local hardware store to hook over the clips. This provides a bit more clip gripping pressure, but will still allow the wand to come off should steam pressure gets excessive.
10/31/2013 9:17:22 PM • Krups Xp5240... • Answered on Oct 31, 2013
Function switch is broken off just where it enters
A parts sheet shows the switch as part of the front fascia. Unable to give you the part number, it depends on which market (country) it is for.
10/19/2013 5:15:12 AM • Krups Xp5240... • Answered on Oct 19, 2013
0answers
0answers
XP4020 - n1164
Krups XP 4020 Semi-automatic Espresso Coffee Maker http://www.coffeemachinemanual.com/krups-xp-4020
5/26/2016 6:34:36 AM • Krups XP Coffee... • Answered on May 26, 2016
Where can I get replacement for the two grille plates of my Krups Grille system 2002
are they shorted ? see if thermal blown
3/9/2016 1:27:56 PM • Krups XP Coffee... • Answered on Mar 09, 2016
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
1/28/2016 11:25:46 PM • Krups XP Coffee... • Answered on Jan 28, 2016
Hello, I have Krups XP-7220. When I try to make a coffee, machine start to ask me for refilling. And this process is endless.
Check the water float in the tank, it is common for them to cease floating sometimes. Krups solution is a new tank, my solution is to jam something plastic underneath it to lift it up so that it activates the sensor. Even if tank is empty it will no longer ask you to fill it up.
2/6/2015 10:03:59 PM • Krups XP Coffee... • Answered on Feb 06, 2015
The frother nozzle makes a bad screeching noise. What am I doing wrong?
I don't think there is a lot you can be doing wrong to cause that apart from maybe something not too well cleaned and creating a restriction for the steam.
2/6/2015 10:01:37 PM • Krups XP Coffee... • Answered on Feb 06, 2015
How do I disassemble Krups dolce gusto KP5000 machine?
You will need an instruction manual, if you leave your email address I will send it as a PDF file.
12/8/2014 6:21:59 PM • Krups XP Coffee... • Answered on Dec 08, 2014
Coffe maker krups xp5220-water come out of the top of the machine not from the hole
Open the machine up and look for a broken hose or similar.
10/2/2014 5:17:23 AM • Krups XP Coffee... • Answered on Oct 02, 2014
How do I fix error code 12
That is a very uncommon error code. It is not detecting the ejection switch pulse, it may be just a case of dismantling and cleaning and checking the switch operation. It's all internal so you need to remove the housings.
9/29/2014 5:55:36 PM • Krups XP Coffee... • Answered on Sep 29, 2014
Krups Xp5240 Perfect Tamp Xp5240 Espresso Machine Logo
9 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
XP Krups
  • XP Krups
Most Popular Question
function switch broken off just enters
  • Coffee Makers & Espresso Machines
