20 Most Recent Sakar Digital Concepts MiniDV Cassette Rewinder with AC Adapter Questions & Answers
Sounds like you encrypted the drive. Under Computer, right click the drive and format it. You will lose all your data and there is no way around this. Write your password down somewhere if you can't remember it.
Electronics -... | Answered on Feb 03, 2020
If you use a fast charger, or a power charger, that can be the cause of your trouble. I used to charge with different power chargers till I learned they push every battery over its limits. After at least 3 different power chargers and about 100 defective batteries, I now charge my batteries with normal slow chargers. Before I can go on a shoot, sometimes 8 slow chargers are charging a whole night. But since I stopped using the power chargers I never lost a battery on overcharging (actually overheating)
Electronics -... | Answered on Jan 12, 2020
This problem was solved before on this site. See link below.
https://www.fixya.com/support/t1672030-pen_drive
When the drive is really defect nothing can help.
But there are several programs you can try to find, to recover data from "defective" drives, cards or whatever.
just google "Recover my files" and try one of the free applications to see if there is still something on the USB drive.
External cards or disks are almost impossible to make secure. You always can reformat and change the label. Are you sure you allow people to bring in external cards, they could have plugged in on other computers? Even computers they are not sure they don't contain viruses or malware? This is more dangerous than being connected to the net.
there are different reasons behind your USB cable not recognize such as:
  • unplug your computer/laptop: unplug the computer from the power supply , because most of the time computer or laptop don't turn off completely and mother board still get power.
  • Motherboard need rebooted: Some times mother board can go wrong and USB ports stop working.in this situation motherboard need reboot.
  • Update Device Driver
  • Restart and Disconnect USB Device
  • Uninstall Hidden Device
  • Uninstall USB Device
  • Update generic USB Hub
for more help i will suggest you customer support help number +1 855-461-5433.
Electronics -... | Answered on Jan 08, 2020
Use an android screw driver to open the android case see the circuit board below see the stuck part take it out re assemble
Electronics -... | Answered on Dec 26, 2019
Connect and get best solution of email related issues. Webmailhelps
Electronics -... | Answered on Dec 04, 2019
format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Electronics -... | Answered on Nov 20, 2019
Mkv files to play correctly require quite powerful computer. Try mpg, MPEG codes but even those when used for high definition video my require some processing power.
Electronics -... | Answered on Nov 12, 2019
Flash memory probably corrupted, you may need to format to get it useable, you will lose data but you can try a data recovery app which should retrieve most of the data even after formatting.
Electronics -... | Answered on Nov 05, 2019
Change the region code for all DVD cd's through the supplier
Electronics -... | Answered on Nov 02, 2019
It's possible that you or someone has accidently changed the region code setting on the player.
If you type your model number and the words 'region code' into a search engine, you should find out how to reset it to your region or make it region free.
If that doesn't work there's an electrical fault on the machine.
Electronics -... | Answered on Oct 31, 2019
Tip
How to repair Motorolla Talkabout 250 antenna
I have just repaired four of these radios, with complete success.
You need a tube of black Stixall (currently £5.81 from Tool Station), a skeleton gun and a saucer of water with a good squirt of washing up liquid.
Take the back off the radio, take out the batteries and remove the rear cover by undoing the retaining screws using a screwdriver with a star shaped bit. Unscrew the circuit board now exposed using the same screwdriver bit. Remove the damaged rubber aerial with coiled copper core, being careful not to damage or distort the copper core. It lifts off one of the screw lugs revealed when removing the circuit board. Get rid of all of the old rubber.
Now put the end of the copper coil back over the lug (where it came from) and screw the PCB back on followed by the back of the unit.
Now form a new rubber cover to the copper aerial using Stixall, squirted into place. Squirt it down into the aerial housing so that it will get mechanical purchase from the body of the radio. Put on plenty, completely coating the copper aerial. Now dip your fingers in the saucer so that they don't bond to the Stixall and mold it into a smooth aerial shape. Leave it to cure for 24 hrs and then dust it with flour. Job done.
I have tested my repaired radios and they are great, the new "aerials" have lasted well. I am especially pleased that I don't have to throw them away.
Good luck - regards SJP
on Oct 16, 2019 | Electronics - Others
Plenty here;
https://ksp-electronics.com/en/product/view/5741-ta1319ap
Electronics -... | Answered on Oct 15, 2019
Error. Over Current - Peak current exceeded
Possible causes:
Motor has a short - Phase to phase or phase to ground.
Motor cable damaged/defective.
Motor cables too long.
Acceleration/deceleration ramps too short.
Damaged output phase of inverter.
EMI
Electronics -... | Answered on Oct 14, 2019
Three years is pushing the life of the batteries. Have them checked where your type of battery is sold.
Electronics -... | Answered on Oct 13, 2019
Sakar Digital Concepts MiniDV Cassette Rewinder with AC Adapter Logo
0 questions posted
Top Sakar Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Sakar Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Sakar Electronics - Others
Most Popular Question
dpfmate software not available
  • Electronics - Others
