20 Most Recent
GCC Technologies Elite XL 608 Laser Printer Questions & Answers
When fuser is hot (10-15
The thermostat on the fuser is failing. Toner requires the fuser to operate at a specific temperature range, too hot or too cold and it begins to stick to things it shouldn't and fall from things is should (like your paper)...in your case the thermostat is not stopping the fuser as it gets too hot. Not only will this eventually cause scoring and melting inside the printer, possibly fire...it means the printer only prints well as the fuser heats up through it's optimum range then you begin to get smearing.
Connection/driver for OS 10.3.9
Please visit the GCC website: gccprinters.com. Under the Support tab, you will see instructions for connecting the printer to your Mac. Please understand there is no "driver" under Postscript printing. You install the printer description into the Library folder using the installer on the website. If you have further difficulties, please email me (no charge)
[email protected]
Won't print from Illustrator
Sound like the printer has lost its pdf post script discription file.
Try this open abobe ills seperator file just right of the files picture is set descript file click on window
a set pdf to match your printer.If file is not available to may need to do a clean removal & reinstall printer software. Hope this helps
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
How to change tax rate on spl-290 calculator
* Press *N/C/CE *****n* Enter 200* Press the TAX+ *****n* The display will sh*w the t*tal price TAX+ 210* Press the TAX+ *****n again* The display will sh*w the tax am*unt TAX 10* *r the price after tax is $58.5, what is the pre-tax price and tax am*unt:* Press *N/C/CE *****n* Enter 58.5* Press the TAX- *****n* The display will sh*w the pre-tax price TAX- 55.72* Press the TAX- *****n again* The display will sh*w the tax am*unt TAX 2.78
My conlog is showing minus - 11.06 kwh
You mentioned a reading of minus 11.06 kWh. Here's what it means:
Remember that this is a prepaid meter, so the negative value suggests that you've used more energy than what was prepaid
The meter has consumed 11.06 kilowatt-hours (kWh) more energy than it has generated or received.
This negative value indicates that more energy was used than supplied during the specified period.
LED Indicator:
The meter has an LED light that flashes when electricity is consumed.
When you use electricity, the meter balance decreases, and the LED light provides a visual indication of energy flow.
Plz tell me error code 21 how to fix it for ultrasonic comfort 400 nebulizsr
As you know, this is a medical device. I suggest you consult a medical professional about it as it affects your treatment. The device is Japanese in origin. The instruction manuals I encounter are written in Japanese. That may or may not prove to be an impediment to you contacting the company yourself for guidance. I am reluctant to advise you about the equipment as my guidance would be very, very general and your health is much too important for trial and error. A low battery can generate error messages. Turning it off, unplugging it, waiting a few minutes, plugging it back in and turning it on might clear the problem. Some nebulizers have a reset button.; I can't say being unable to read the manual readily. Assuring all its parts are assembled correctly is of course worth doing. The company: Koushin Industries, Inc. (Japan):
Address: 1000-1, Hirakata, Ageo, Saitama, 362-0059, Japan.
Phone: You can reach them at the provided address.
Website: Visit their website for more information: Koushin Industries, Inc. However, I find the information there to be in Japanese. Again, I suggest you consult a medical professional.
