20 Most Recent
Dacor Millennia DHI602 Kitchen Hood Questions & Answers
see this steps and fix it. God bless youSwitch
If the range vent hood fan and light are not
working the switch might be defective. Watch our video on switch
testing and test this switch for continuity.
Selector Switch
working the selector switch might be defective. Watch our video on
switch testing and test this switch for continuity.
Rotary Switch
working the rotary switch might be defective. Watch our video on switch
Rocker Switch
working the rocker switch might be defective. Watch our video on switch
Switch Kit
working the switch kit might be defective. Watch our video on switch
Micro Switch
working the micro switch might not have continuity. The best way to test
the switch is with an Ohm meter. See our switch testing videos for help
testing this micro switch.
Thermal Fuse
working the thermal fuse may have blown. It can be tested for
continuity. Watch our fuse testing video for more information.
Main Control Board
If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board
working the user control and display board may be defective. Check other
causes before ordering this board.
Dacor Millennia...
Answered
on Sep 09, 2013
https://www.youtube.com/watch?v=mlmfKjQdrAo
Dacor Kitchen...
Answered
on Apr 11, 2020
Most gas stoves come from the factory ready for natural gas service,as most of the world is piped for natural gas when gas is used as a fuel,but they are easily converted to LP ( liquified petroleum) gas by installing a conversion kit. As this gas is very explosive I wouldn't recommend a homeowner tackling this job themselves,but hire your gas supplier to do the conversion or a licensed contractor.
The added expense of hiring a licensed contractor is far cheaper than loosing your home and possibly serious injury or ***** to family members because of a botched conversion job.
Dacor Kitchen...
Answered
on Nov 14, 2019
The element may show continuity (should be very low ohms) however when he element heats up it will open and no longer heat, when it gets cool enough it will heat again and cycle will repeat. I would look at high limit switch while I had it apart. The only true test to verify element is not heating is using a clamp on current meter.
Dacor Kitchen...
Answered
on Feb 12, 2019
use some packing tape stick it on light lens to turn
the hood came with a suction cup for unscrewing bulbs
you could order through dacor or find one in dollar store
Dacor Kitchen...
Answered
on Jan 20, 2019
sounds like the dbl relay is not closing on the relay board
you need sevice
Dacor Kitchen...
Answered
on Jan 20, 2019
yes the cooloing fan runs when oven is turned on and should be set to continue running after oven is turned off
it should be set to run until oven drops below 300 deg f
this can be changed if not set correct
Dacor Kitchen...
Answered
on Sep 21, 2018
