20 Most Recent Electrolux Sanitaire SC688A Upright Vacuums Carpet Shampooers Vacuum Cleaner Questions & Answers
2answers
Changed filter and bag. starts then stops
This will happen if the bags are either incorrectly fitted or are non genuine bags that are not within the tollerance, size wise, for the machine.
4/15/2024 10:30:18 PM • Electrolux... • Answered 6 hours ago
2answers
Electrolux central vac system with service lit in screen. What needs serviced?
Check the motor compartment to clean out dust if needed, motor brushes, relay and filters. It's a good idea to service your power nozzle once a year too.
2/17/2024 4:23:20 AM • Electrolux... • Answered on Feb 17, 2024
Electrolux 2100 will not cut off, replaced swich, still won't cut off
See position of switch in the manual. It may possible, mains wires are sort that is by passing switch. Use Of Standard Attachments; Operation - Electrolux 2100 Instructions Manual [Page 6] ' ManualsLib
1/14/2024 1:21:09 PM • Electrolux... • Answered on Jan 14, 2024
2answers
Electrolux stick vacuum won't charge. Light comes on when set in the charger but goes out after1 second.
normally the battery gives up in this vacuum cleaners through my experience
confirm the charger first
use a voltage tester to check the voltage coming from the charger
the voltage will read from 12volts to 18 volts
depending you vacuum model.
If you the voltage is present then the battery is dead.
1/4/2024 1:22:26 AM • Electrolux... • Answered on Jan 04, 2024
Electrolux Trilobite Robotic Vacuum. What is error 18 on Electrolux Trilobite please?
Question edited for full 'make model (what it is)'. Question moved from Washing Machines.
Trilobite error 18 Battery Fault?
RobotReviews http://www.robotreviews.com > chat > viewtopic May 25, 2011 - I suspect it happens when a discharged battery is very weak, and may be because the 15 sub-C NiMh cells of one battery are dis-equilibrated.
Messages D'erreurs; Fehlermeldungen - Electrolux ...
ManualsLib https://www.manualslib.com > ... > Overview manual Electrolux Trilobite Manual Online: error messages, Messages D ... our Customer Service, see page 18. The errors you can correct yourself are.
Trilobite error 18
Fixya https://www.fixya.com > ... > Trilobite Vacuum Sep 7, 2009 - Trilobite error 18 I looks like charging problem. Could you please give advice by myself. - Electrolux Trilobite Vacuum question. ..
12/12/2023 4:28:54 PM • Electrolux... • Answered on Dec 12, 2023
Electrolux h5005
Can't find the question for the Electrolux vacuum cleaner H5005, but I have one of my own: Where can I get a wheel for this model?
11/27/2023 3:00:06 PM • Electrolux... • Answered on Nov 27, 2023
2answers
Replace belt on Electrolux Epic 2500 SR Upright
1. Start by removing the screws that secure the bottom plate of your vacuum. 2. Once the bottom plate is removed, you will find the belt inside, as well as the belt pulley and drive wheels. 3. Disconnect the belt from the belt pulley. 4. Align the new belt over the belt pulley and drive wheels so that the teeth of the belt match up with the grooves on the pulley. 5. Wrap the belt around the pulley and drive wheels, and then reattach the belt to the pulley with the supplied clips. 6. Reassemble the vacuum and you're done!
10/31/2023 9:17:07 PM • Electrolux... • Answered on Oct 31, 2023
2answers
Model pu3650b central vacuum. How can I reset the service indicator?
change the filters
3/15/2023 9:08:37 PM • Electrolux... • Answered on Mar 15, 2023
Electrolux Legacy runs without the bag but shuts down as soon as the bag is inserted?
Help here. It says a clog or the valve that senses airflow and tells the motor to cut out to protect itself. https://www.google.com/search?q=Electrolux+legacy+runs+without+the+bag+but+shuts+down+as+soon+as+the+bag+is+inserted ..
3/5/2023 6:31:35 PM • Electrolux... • Answered on Mar 05, 2023
Electrolux OX3 vacuum works for 2 seconds, cuts out, then works etc. Does the same when hose and filter disconnected.
Yes, that is probably overheat protection on the motor. Probably worth fixing, although some of the reviews are not good and mention poor quality. https://www.google.com/search?q=Electrolux+oxy3+vacuum+works+for+2+seconds%2C+cuts+out ..
1/13/2023 5:40:49 PM • Electrolux... • Answered on Jan 13, 2023
Where can I find a manual for the Electrolux PowerPlus Z4471 cylinder vacuum cleaner?
You may be able to find a manual for your Electrolux PowerPlus Z4471 cylinder vacuum cleaner online or by contacting Electrolux directly. Here are a few suggestions for finding a manual:
  1. Search online for the make and model of your vacuum, along with the word "manual." You may be able to find a downloadable PDF of the manual or purchase a physical copy from a third-party seller.
  2. Check the manufacturer's website. Many manufacturers make manuals available for download or purchase on their websites.
  3. Contact the manufacturer directly. You may be able to request a copy of the manual from the manufacturer's customer service department.
1/4/2023 1:08:42 PM • Electrolux... • Answered on Jan 04, 2023
Where can I find a rocker for my
You may be able to find a rocker for the on/off switch of your Electrolux Silverado 1505 vacuum at an Electrolux dealer or an authorized repair center. You may also be able to purchase a replacement rocker online from an retailer that specializes in vacuum parts and accessories. Here are a few suggestions for finding a replacement rocker:
  1. Search online for the make and model of your vacuum, along with the words "replacement rocker" or "on/off switch rocker." You may be able to find a compatible rocker from an online retailer that specializes in vacuum parts and accessories.
  2. Check the manufacturer's website. You may be able to purchase a replacement rocker directly from Electrolux or find a list of authorized dealers or repair centers where you can purchase one.
  3. Contact the manufacturer directly. You may be able to request a replacement rocker from Electrolux's customer service department or find a list of authorized dealers or repair centers where you can purchase one.
1/4/2023 12:55:08 PM • Electrolux... • Answered on Jan 04, 2023
2answers
How do i get my brush roller to spin ?
Hi, Please check that all of your belts are still good (ie not stretched out, torn or otherwise worn). Also, please double check that you've cleaned all debris from the brush roll. You might need a tooth brush or a comb that you can throw out later. You might use shampoo to clean in. Then , please have the brush roll motor checked. Thank you.
10/19/2022 3:18:25 AM • Electrolux... • Answered on Oct 19, 2022
My electrolux washing machine/dryer tripping in the middle of spinning process. Steam appears before it trips the main breaker. What could be wrong wit it?
Hi, Please remove some of the weight of your clothes. The dryer might be working too hard and then overload. So a lighter loads stops the overload. Also, please make sure that you've removed all of the lint from previous cycles. Thank you.
10/12/2022 1:55:37 AM • Electrolux... • Answered on Oct 12, 2022
Electrolux Sanitaire SC688A Upright Vacuums Carpet Shampooers Vacuum Cleaner Logo
4 questions posted
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Vacuums
  • Electrolux Vacuums
Most Popular Question
electrolux cannistor will not come off
  • Vacuums
