seems like there is a short in the unit. it is extremely hard to find kenmore parts. i would probably just go out and buy a new vacuum. Kenmores arent worth fixing.
yes you need to remove the bottom to get access to the flow of the air section, while doing this be sure to clear any debris collected in the roller brush section , if you can't find a manual,, an easy method is just check the sections of the unit where the debris travels and unclog any clogs, be sure and clean the hose section too as the item may be lodged in the hose too
I don't have specific information on the Kenmore upright vacuum cleaner model number 116.31912100 or the part number 8174906, but I can provide you with general guidance on how to remove and install pedals on some vacuum cleaner models. Keep in mind that procedures may vary between models, so use the following as a general guide:
Removing the Pedal:
Unplug the Vacuum Cleaner: Ensure the vacuum cleaner is unplugged to prevent any electrical accidents.
Turn the Vacuum Cleaner Over: Lay the vacuum cleaner on its back so that you have easy access to the underside.
Locate the Pedal Assembly: Identify the pedal assembly on the underside of the vacuum cleaner. It is usually connected to the height adjustment or other features.
Release Tabs or Screws: Look for tabs or screws securing the pedal assembly in place. Use a screwdriver or the appropriate tool to release these tabs or screws.
Disconnect Linkages: Some pedal assemblies are connected to linkages that control various functions. Disconnect any linkages carefully.
Remove the Pedal Assembly: Once the tabs, screws, and linkages are disconnected, carefully remove the pedal assembly from its housing.
Installing the Pedal:
Position the New Pedal: If you are replacing the pedal, position the new pedal in place.
Reconnect Linkages: If your vacuum cleaner has linkages, reconnect them to the appropriate points on the new pedal assembly.
Secure the Pedal: Use screws or tabs to secure the new pedal assembly in place. Make sure it is securely fastened.
Test the Pedal: Manually operate the pedal to ensure that it moves smoothly and engages the desired function.
Turn the Vacuum Cleaner Upright: Once the pedal is securely in place, turn the vacuum cleaner upright and plug it back in.
If you're uncertain about any steps or encounter difficulties, it's recommended to consult the user manual for your specific model or contact the manufacturer's customer support for assistance. They may provide detailed instructions or guidance tailored to your vacuum cleaner's model and part.
