20 Most Recent Fisher and Paykel E522BRXU (171 cu ft) Refrigerator Questions & Answers
The drain at the bottom rear was reamed out using a wire.
Fisher and... | Answered on Dec 07, 2017
Turn the Fridge OFF at the power socket, wait 10 seconds and turn it back On. If still beeping, You will need a Service Technician to assist with this.
See the site below for more help or to schedule a tech visit.
Fisher and... | Answered on Mar 27, 2020
Try blowing compressed air up the drain tube.
Fisher and... | Answered on Jan 04, 2020
F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires together with a auto12v type connecter or solder it and use shrink tube. Switch the fridge back on and hay presto, you can fill your fridge to the max 3 times over with the money you just saved. It will happen again as the wiring loom they fit is well and not flexible. Use silicone insulated wire from J-car or similar and replace from the plug and reconnect inside the door where the wires don\'t bend. Hope this helps you.
Fisher and... | Answered on Oct 27, 2019
HEY!!!!! If your breaker is tripping it means you have a short circuit - a serious safety issue.
Unless you are a qualified electrical tech, for safety reasons refer this one to a pro.
Fisher and... | Answered on Oct 18, 2019
make sure it is totally defrosted before attempting to remove it they can be a little awkward, usually there is some kind of retainer to keep the collection grill in place if not then you need to been it outwards to reach the element,before you do that disconnect the element and test it with a multimeter to make sure it needs replacing
Fisher and... | Answered on Mar 28, 2019
CALL A LOCAL REPAIR SERVICE COMPANY
Fisher and... | Answered on Feb 11, 2019
The beeping is in most cases to alert you to the fact the temperature is above the safe limit.
Fisher and... | Answered on Feb 08, 2019
It is difficult to diagnose without providing a model number to your refrigerator however I am wondering it is equipped with an ice maker? It is common for fridges to come with one and many are not hooked up to a water line. If this happens, then the ice maker will continue to cycle trying to get water. The inlet valve in the back of the unit will buzz when there is no water pressure going to it. Please check your owners manual on how to turn the ice maker off if it has one and it is not hooked up.
If this is not the issue, then please give a model number for further assistance.
The F15 error code refers to "Low Current from fan" not drawing enough current or open circuit to fan. Check wiring to fan, check fan motor with Digital Muli-meter for resistance - if open circuit or high resistance - replace fan.
Fisher and... | Answered on Jan 31, 2019
Fisher and Paykel E522BRXU (171 cu ft) Refrigerator Logo
1 questions posted
Top Fisher and Paykel Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Muntejaya Ginting
Muntejaya Ginting
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Refrigerators
Most Popular Question
fisher paykel n369b model water pooling
  • Refrigerators
