20 Most Recent
GE GSL22JFXLB (22 cu ft) Side by Side Refrigerator Questions & Answers
GE Icemaker
Switch sounds like its sticking. Micro switch needs to be replaced
Ice Maker working, but water not dispensing
There are two sides to a dual water control valve. One side fills the ice maker and the other side is the dispenser. If one side goes bad you will need to replace the whole dual water control valve. If your model is the GSL22JFXLB your replacement is the=>
WR57X10032 Water Inlet ValveThis part is found on the rear of your refrigerator near floor where the water from your home hooks up to your refrigerator, Thanks
Sea Breeze
Too much water dispenses to ice maker
The adjustment is going to be located on the ice maker its self, on the big white part. It's more than likely going to be concealed by a plastic tab. Keep in mind that the water valve could be sticking to. Adjusting the water fill amount could result in no ice or a flooded fridge. Keep that in mind If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
For a GE refrigerator model GFSF6KEX, how do you remove the ice tray? (Not the freezer drawer, just the tray.)
To remove the ice tray from your GE refrigerator model GFSF6KEX, follow these steps:
Empty the Ice: Before removing the ice tray, empty it of any ice cubes. This will make it easier to handle.
Locate the Ice Tray: The ice tray is typically located in the freezer compartment, usually near the ice dispenser or ice maker.
Grasp the Bottom Edge: Stand in front of the freezer and open the door. Grasp the bottom edge of the ice tray on the sides. Be cautious not to place your fingers near the opening at the bottom front part of the bucket where the crusher blades are located.
Lift Up the Front: Lift up on the front of the ice tray so that it clears the stops on the ice bucket rail.
Pull the Tray Forward: Pull the ice tray forward and out of the freezer compartment.
Reinstalling the Tray: To reinstall the ice tray, follow these steps:
Line up the flange pieces on the sides of the tray with the channels in the ice bucket rails.
As you push the ice tray all the way back, lift the front of the tray so that it clears the stops on the front of the ice bucket rails.
Verify that the tray is properly inserted by pulling it forward. It should hit the stops on the rail and not come out. If it does, push the tray further back.
Check for Misalignment: If you're unable to push the ice tray all the way back, it might be due to a misalignment between the back of the auger (located in the tray) and the prongs on the auger motor (mounted in the back freezer wall). To fix this:
Remove the ice tray.
Close the freezer door.
Press the dispenser for cubed or crushed ice; you should hear a snap.
Open the door again and reinstall the ice tray.
Remember to handle the ice tray carefully, especially if it's full of ice.
