20 Most Recent
Stoves 600GR Gas Single Oven Questions & Answers
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Stoves 600GR Gas...
Answered
on Jan 13, 2012
My oven does not turn on
HELLO.
It is obvious that there is no electric power supply in your microwave oven.
solution.
The problem of your microvave is likely to be from the fuse or wiring connection connected to the panel.
What you need to do fix up the problem from easy to hard , first of all
is to carefully unplugged the plug from the wall then allow it to relax
for some time then plug it back again to the power supply correctly to
see if the problem will be solve ,
Then take a look on the fuse and also the wiring mention above the fuse
is some time located at the tip or the mouth of the plug depending on
the type of the wiring connection on the oven or inside the oven it
self which will need to be check on and same condition is apply on the
wire as well.
Please get back to me for further instruction if necessary.
Thanks.
Stoves 600GR Gas...
Answered
on Sep 19, 2011
