20 Most Recent Wolf Range KFS027WS36 Stainless Steel Gas Oven Questions & Answers
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Wolf Range Ovens | Answered on Jun 04, 2020
Dear Friend,
Pull the oven towards you, disconnect any electrical cord from the wall. Normally the fuse is located right next where the electrical cord enter in the back of the stove. If there is any panel right on top of where the electrical cords connects to the oven, simple removed that cover and there should be a fuse. If not, removed the rear panel where the electronic control panel is. Hope you can find it!
Good Luck!
Wolf Range Ovens | Answered on Sep 20, 2014
i have original papers on those ovens... and can fix them
Wolf Range Ovens | Answered on Oct 27, 2013
you proably have an element out
Wolf Range Ovens | Answered on Sep 25, 2013
Wolf Range KFS027WS36 Stainless Steel Gas Oven Logo
1 questions posted
Top Wolf Range Ovens Experts
Harjeet s. bola
Harjeet s. bola
ray gallant
jenifer ronan
jenifer ronan
Level 1 Expert
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
View Most Popular
Wolf Range Ovens
  • Wolf Range Ovens
Most Popular Question
find fuse location wolf double oven
  • Ovens
