20 Most Recent
Philco (R) 841.205 CD Shelf System Questions & Answers
Replacement needle
go on ebay,if you carnt get it there,look on the back,or underside,of unit,you will see a model number,and there may be a website address,but I would try ebay first....jim
Won.t play
on some cd players, when they are closed ,they also push a button or little springloaded switch to let it know its loaded. Now eventually these doors wear down and dont quite push the activation switch all the way
yours is inside the box and can sometimes be temporirily jammed down with blue tack or tape
Ive had the same problem and in the end its time to buy another system my friend
Clapster
Cd keeps coming back out
HelloThe loading mechanism should be replaced. It has gear wheel trouble. It will be best to replace the loader mechansim, as it won't cost more. OK.
How do you get the turntable to start turning?
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
Turn Tble will not turn.
open up the top (where the record player is). Take off the pad, then remove the little c-clip surrounding the metal peg (in the center). Remove the turn table. Check underneath to see if the strap/belt is rather broken or has slipped off. If it broke, you have to go buy a new one. If it slipped off, put it back on. Put one end of the belt around the white plastic peg (the one that turns) and then the rest goes around the first outer ring on the bottom of the turn table (the middle one, between the outer edge and the middle insertion area. Its a real pain in the **** to do because it slips off a lot the first couple times...but you will get it eventually :) Once that is done put the table back on, test it, if it works put the c-clip back on (which is a lot harder than taking it off if I do say so myself lol) Put the rubber cover back on and Voila! You have a working turn table. For those with a broken belt use this as a replacement guide :)
Good luck guys and enjoy some good ol' Vinyl cause they are making a comeback!
How to place the belt on the turntable.......
Suggestion:
Pull rubber matt off TT. Use a small screw driver to pop off the small black "C" clip at base of steel record post. UNderneath plastic disc you will see the belt, and it loops on the metal post and over to the plastic barrel shaft to its right. Try this:
- Using Non-gelatin based nail polish remover OR acetone (gotten from any hardware store), and a few Q-Tips, rub the belt inside and out along its entire length until you feel the tacky rubber feeling come back to the belt. You may also see the shiny surface come off the belt as you clean it. The shiney look is from belt slippage and its like a glazing. Also, if you notice any of this black glazing on the two belt posts, clkean them off as well.
- If belt broken, replace with new by looping it back around the two posts under plastic TT platter.
If its truely a belt issue these two should solve it.
