20 Most Recent Kelvinator KCG130GW Freezer Questions & Answers
Fixya is unable to suggest sources for Kelvinator parts.
Kelvinator... | Answered on Aug 10, 2018
freezer --no
every time you open the freezer door , the cold air is dropped to the floor so the unit has to work hard to bring the temp back down same as any up right freezer
fridge --it is as efficient as the rest
Kelvinator... | Answered on May 19, 2018
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Kelvinator... | Answered on Dec 04, 2016
First meter the fan motor to see if it receiving 120Vac, if it is, but does not spin- replace the motor. Order the part by MODEL number Help Me Find My Model Number RepairClinic com
Kelvinator... | Answered on Oct 14, 2016
Search by keyword GOExample: beltreturn to model detailsI will find it in cabinet
Kelvinator... | Answered on Jun 30, 2015
Depending on the model you pull the cover from evap coil and you will see either a bimetal thermostat or the timer
Adjusting the thermostat clockwise will normally lower the freezing temperature on unit.. If it does not, either the thermostat is defective or perhaps the unit is low on refrigerant.
Kelvinator... | Answered on Mar 09, 2015
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Kelvinator... | Answered on Mar 03, 2015
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Kelvinator... | Answered on Jan 08, 2015
Yes it is. Just rotate it clock wise and vice versa and see it will work in case No then check the gas
Kelvinator... | Answered on Sep 29, 2014
MEASURE THE EFFICIENCY IN COOLING. IT WILL TELL U IF THERE IS NO GAS OR LESSER QUANTITY OF GAS. THE VENDOR COULD MEASURE IT WITH HIS METER
Kelvinator KCG130GW Freezer Logo
3 questions posted
Top Kelvinator Freezers Experts
ray gallant
knot
knot
Tom Chichester
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kelvinator Freezers
  • Kelvinator Freezers
Most Popular Question
kelvinator opal upright freezer over
  • Freezers
