20 Most Recent Beverage-Air CFG24 Freezer Questions & Answers
Check the fans are running ok, and the condensing area isn't too hot. Check the door closes properly and the inside isn't blocked up with ice. If all appears ok you may have to call out a technician
Beverage-Air... | Answered on Aug 22, 2012
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Beverage-Air... | Answered on Jan 21, 2011
What does ( da ) mean on a beverage two fan single door reach in frezzer disply
Beverage-Air... | Answered on Aug 08, 2015
Most all manufacturers try to build units to hold between 34 to 38 degrees as this is the most commonly accepted range for coolers by all Health Departments.
Beverage-Air... | Answered on Oct 06, 2010
dirty condencer coils bad fan motor or compressor start relay on the side of compressor or turned off then back on without waiting 5 min.
Beverage-Air... | Answered on Dec 09, 2009
There are video's on google that have trouble shooting for Igloo ice maker types and for the Igloo ice company and YouTube.
Freezers | Answered on Aug 05, 2020
Cool and keep cool.
Freezers | Answered on Aug 04, 2020
Question posted under freezers but appears to be Ameriwood Industries furniture.
If you can identify the model number, you can download a free manual from Ameriwood Industries, which has a contact phone number to call for another model if that is different model furniture.
Example with telephone number:
https://www.ameriwoodhome.com/eng/AmeriwoodFiles/ProductDocuments/AmeriwoodFiles/ProductDocuments/19452_B345531309KP00%20instruction%20manual.pdf
https://www.ameriwoodhome.com/eng/instructions
Freezers | Answered on Jul 01, 2020
I wonder what the fixya software asterisked out?. Can you write the word
v
e
r
i
c
a
l
l
y
Freezers | Answered on Jun 29, 2020
Hi I have the same problem,
did you get an answer to your question..?
Freezers | Answered on Jun 15, 2020
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
That alarm light means that the unit was too warm for a period of time. The door may not have closed properly. It is a warning to you that the food may have thawed out. It does not mean something is wrong. To reset it switch it off and on or unplug it for a minute.
Freezers | Answered on Jun 14, 2020
Beverage-Air CFG24 Freezer Logo
7 questions posted
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Tom Chichester
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Freezers
Most Popular Question
beverage air model cfg24 1 evaporator
  • Freezers
