20 Most Recent Char-Broil Big Easy OilLess Infared Turkey Fryer Electric Questions & Answers
Get the manual for the Turkey fryer.You will get the instruction from there.
Char-Broil Big... | Answered on Jan 22, 2011
You can get the cooking guide at http://www.charbroil.com/bps/char-broil/char-broil/knowledge/10101480%20cooking%20guide%20english.pdf
I also found this assembly instruction manual at http://www.charbroil.com/bps/char-broil/char-broil/knowledge/10101480%20english.pdf
And a supplement to the instructions at http://www.charbroil.com/bps/char-broil/char-broil/knowledge/10101480%20supplement.pdf
If you have trouble with the links, you can visit www.charbroil.com and select your fryer to find the documents.
Hope this helps!
Char-Broil Big... | Answered on Dec 05, 2010
You should be able to find it at the following link. Just enter your model number. I hope this helps.
Normal 0 http://www.charbroil.com/Support/ProductLookup.aspx
Char-Broil Big... | Answered on Jul 06, 2010
I';m sure everyone thinks they are giving good advice, but READ THE SYMPTOMS. The guy says his ignitor doesn't "click" anymore. And most of you tell him he needs a new gas regulator. Fix his problem, don't create new ones. He needs his ignitor fixed. Maybe just a new battery? Or maybe the whole ignitor unit But certainly not a new regulator, etc, etc.
Char-Broil... | Answered on Sep 02, 2019
A Dremel tool with a brass or steel wire brush works wonders.
Char-Broil... | Answered on Dec 27, 2018
try amazon for a replacement sparker
Char-Broil... | Answered on Jul 10, 2018
Igniter is combined in the valve of grill so the best way is change the new one. or cross flame from other burner.
Your venturi could be clogged up. clean the burner holes with a straightened paperclip, then take the burners out and do the same to the venturi that deliver gas to the burners. If that doesn't do it, you may have a bad regulator.
Char-Broil... | Answered on Mar 02, 2018
why don't you state the problem first. what is not working?
Char-Broil... | Answered on Oct 01, 2017
I hade the same problem! the new propane bottles the valve inside where it screws in it wont open
all the way?.
Char-Broil... | Answered on Jun 22, 2017
Depends on your cooking preference.
Char-Broil... | Answered on Apr 23, 2017
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Char-Broil... | Answered on Aug 03, 2016
Char-Broil Big Easy OilLess Infared Turkey Fryer Electric Logo
8 questions posted
Top Char-Broil Grilling Experts
Paul Carew
choprboz5
Charles Tidwell
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
View Most Popular
Char-Broil Grilling
  • Char-Broil Grilling
Most Popular Question
lost instruction manual big easy
  • Grilling
