20 Most Recent 2005 VW Jetta for L4 2.5L Engine ID BGP or BGQ Front Wheel Hub Questions & Answers
please complete your question
2005 VW Jetta... | Answered on Sep 11, 2015
I have seen this on many vehicles. It is entirely possible that when you last parked and shut it off you had the steering wheel turned to the left or right rather than centered straight ahead. The power steering was assisting with holding it in that position until you shut it off. At that time power assist stopped and the wheel is resting firmly against the theft lock mechanism. Grasp the steering wheel firmly and if your front wheels are pointed to the left then force the steering wheel to the left a bit more and turn the key will holding the wheel, if front wheels are to the pointing to the right then force the steering wheel to the right and turn the key. Try NOT to turn off the ignition with the wheels not pointed straight.
1A Auto Parts... | Answered on Feb 12, 2015
sorry but they did not make any car's back then...try re entering your info again
1A Auto Parts... | Answered on May 28, 2014
Double check your gas cap. Make sure it is not cracked or tighten probably.
1A Auto Parts... | Answered on Jan 07, 2014
I had a problem similar to that which you described the car would start fine then few seconds later it would cut out completely.
i changed the fuel pump, Fuel pump relay and still the problem was there and a a code of P0230 i cleaned the ECU connections which still didnt change anything so i put a jumper wire to bypass the fuel pump relay it got it to work fine.
With abit more digging and head scratching i opened up the ECU and found one wire broken.
I soldered it back in place and behold the car worked a dream no problem ever since.
I also removed the bypass which i put on the fuel pump relay and put the relay back.
Dont know if this would fix your problem but hopefully it would be of help.
Vehicle Parts &... | Answered on Jul 10, 2020
Yes, you should go for car wrap, it has many advantages like a high quality film will help you to prevent color fading, flying glass splinters during accidents and heat protection etc.
A nice Auto folie will enhance the appearance of your vehicle.
Vehicle Parts &... | Answered on Jun 09, 2020
you can purchase from:
https://www.amazon.com/Adapter-Charger
Vehicle Parts &... | Answered on May 29, 2020
https://help.compustar.com/s/article/How-Do-I-Exit-and-or-Enter-Valet-Mode
You can see this link.
Vehicle Parts &... | Answered on May 07, 2020
Suggest to do a patent search and review some diagrams. That will get you started.
Vehicle Parts &... | Answered on Feb 13, 2020
Google
year make model valet button
it is impossible for us to guess!
Vehicle Parts &... | Answered on Jan 12, 2020
on a car security, no idea, but on Android, this is how.
How to reset your Android screen lock security pattern ... TechRepublic Draw the pattern, click Continue, draw the pattern again, and you're back in business. You can also increase the security of your phone by setting it to lock ...
How to reset your Android screen lock security pattern TechRepublic
Vehicle Parts &... | Answered on Jan 06, 2020
When I hold the valet switch like am ask the led light lights up and stays on no chirping at all but if I hold the valet switch when the car is in the on position I get a chirp help someone please
Vehicle Parts &... | Answered on Dec 28, 2019
The supposed science behind polygraph tests is flawed, even proponents say it's only 90% accurate, (critics say it's far less at 70% or lower) so, at a minimum, for every 10 people that are tested 1 of them either gets accused of something they didn't do, or gets away with doing something. (or 3 out of 10 if you take a critic's side) And when it's done by Police, they are legally allowed to lie to you about your results!
Vehicle Parts &... | Answered on Dec 11, 2019
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Vehicle Parts &... | Answered on Nov 30, 2019
2005 VW Jetta for L4 2.5L Engine ID BGP or BGQ Front Wheel Hub Logo
2 questions posted
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Mike Stager
Mike Stager
Marvin
Marvin
Harrie
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • 1A Auto Parts Vehicle Parts & Accessories
Most Popular Question
starts but accelerating
  • Vehicle Parts & Accessories
