20 Most Recent
Wahl 9854400 Hair Trimmer Questions & Answers
HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
Wahl designer clippers pulling hair
Oiling blades and sharpen them will help to fix the issue. However several reasons can cause this issues such as the low power, broken blades etc. https://pakcentric.com/wahl-magic-clip-pulling-hair/
How to reattach the blade on Wahl model number 9639
- Slightly loosen both blade screws, just enough to be able to shift the blade. ...
- Align bottom blade with the top blade. ...
- Extreme left hand tooth of the top blade must be on the first small tooth of the bottom blade.
- After blade is aligned, tighten screws.
- Plug clipper in.
