20 Most Recent
Quasar TP-2009D 20" TV Questions & Answers
How do i fix a crt tv with a horizontal line
I would look for an open resistor in the vertical section and investigate the power supply since you don't get the click. You may not be getting power to the vertical section.
Quasar VV-2009
Here is the link to the manual if you need it;
http://service.us.panasonic.com/OPERMANPDF/VV1309.PDF
check page 26 item 4 - vcr lock - just a possibility this may solve the problem, long shot.
Let us know which remote you have and we may be able to find out how to program it for your tv.
page 37 gives you contact details if you want to buy the correct remote.
I suspect that with the correct programming, your universal should work fine though.
Hope this helps :)
Vcr
thes happens with every tape?? could be something inside the mechanism like a label fromn a cassette or something dropped in but may also need to be reset..turn on power Power and hold down together the play and Fast forward buttons for a few seconds
1977 CRT TV wont turn on
Not sure why anyone would want to repair a non hd TV as the picture quality isn't usable with modern content but if you're doing it because you like restoring something vintage here are some ideas. Some CRT sets use a pulse from the back side of the flyback transformer as a starter voltage supply, it needs this short pulse to start the power supply, it's kind of like starting a gas motor, the starter only runs for a short time then the gas motor takes over, this signal needs to be measured with a scope or a high end meter, this was a common issue with a lot of older CRT sets that use this type of power supply. I'd look at the start up supply as without that the regular supply isn't operatable.
I have a Quasar 50in model number sq5000
Your EEPROM is bad, if you can find one and have soldering skills and the equipment to remove and replace SMD devices that's the cheap way to fix( $15) if not replace the main board, in your case with the sound issue it may make more sense to replace the main as that should correct that isue as well
