20 Most Recent Audio Technica ATLP120USB Turntable Questions & Answers
I didn't know that a turntable had bass control on it. If it has why not turn the bass down? I think it is your receiver not the turntable
Audio Technica... | Answered on Nov 27, 2014
RCA LEAD IS DAMAGED, CHANGE IT.
Audio Technica... | Answered on Nov 03, 2013
Check that the cartridge is fitted properly.
Audio Technica... | Answered on Jan 14, 2013
reverse the phono cables to see if the other side goes out if it does you could have a bad cable or the wire is off at the catridge.
Audio Technica... | Answered on Dec 20, 2012
Hi, the transformer that supplies power to the motor has been fried by the 220v input and will need to be replaced. If you remove it and go to your local electronic parts supplier they should be able to sell you a replacement. Cheers John styluscity.com
Audio Technica... | Answered on Dec 05, 2011
Just turn up the weight on the arm slowly bit by bit till the problem stops. The weight should have numbers on it - set it at 2 and increase it. You will have to stop the record playing each time you increase the weight. Also look around to see if it has an Anti-skate control, if it has again increase that in stages. It's all down to trial and error setting up a turntable, there's no correct way and it depends also on the records too and quality of them.
Audio Technica... | Answered on Apr 27, 2011
Use an alternative device connected to the input the turntable usually connects to. If both channels work ok the new turntable is clearly faulty and should be returned under warranty.
Audio Technica... | Answered on Mar 05, 2018
Audio Technica ATLP120USB Turntable Logo
Popular Tags
17 questions posted
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Colin Stickland
Colin Stickland
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Audio Technica Audio Players & Recorders
Most Popular Question
much bass
  • Audio Players & Recorders
