20 Most Recent Alesis TapeLink USB Single Cassette Deck Questions & Answers
It would seem so. Normally you only find this on trial software, when they don't give you access to all the features.
Alesis TapeLink... | Answered on Feb 25, 2013
What's your hurry? You copy a tape once but listen to it forever in real-time without fear of it wearing out or degrading. Shouldn't it be as faithful a copy as you can get?
Downloads here:
http://www.alesis.com/tapelinkusb#
A little advice.... if you have any desire to transfer the higher frequencies from your cassettes to your digitized copies, do it at normal speed. The hi-end response of the deck is ok at normal speed but doubling it will double the playback frequencies, making incapable of reproduction with any fidelity.
Frequency Response
(-20dB recording)
Chrome tape 40-15000Hz (±3dB)
Normal tape 40-14000Hz (±3dB)
(0dB recording)
Chrome tape 40-8000Hz (±3dB)
Normal tape 40-8000Hz (±3dB)
Imagine what its response at, say, 30000Hz might be. That's what doubling the playback speed would demand from the head and electronics. It ain't hi-fi anymore.
Alesis TapeLink... | Answered on Feb 13, 2011
then something is open in the signal path....bad bypass switch, broken trace..etc..
Alesis Audio... | Answered on Sep 20, 2014
I have one, it is about as thick as a dictionary...
You first need to check whether the relay you have used as a replacement has the same voltage on the coil as the original. You have wisely chosen one with a higher current rating on the switch contacts, which is a very good idea, but I suspect you've not looked at the coil voltage to ensure it's the same. For example, you may have installed a with a relay with a 12 volt coil, while the original had a 24 volt coil. Result? the new relay coil will overheat, as will the driver transistor.
A simple test is to operate the amp until it feels hot, TURN IT OFF, quickly remove the top cover and see if the new relay feels hot. If it does, you need to source a replacement relay with the correct coil voltage. Usually the coil voltage is written on the body of the relay somewhere, so you should be able to identify it on the original unit airly easily
Alesis Audio... | Answered on Apr 10, 2014
Alesis TapeLink USB Single Cassette Deck Logo
Popular Tags
2 questions posted
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Alesis Audio Players & Recorders
Most Popular Question
ho use
  • Audio Players & Recorders
