20 Most Recent Nike Triax CV10 Wrist Watch Questions & Answers
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nike Triax CV10... • Answered on Jan 19, 2013
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sorry, but going to have to refer you to Nike for this one at:
http://www.nike.com/timing/
Best of luck
Nike Triax CV10... • Answered on Aug 17, 2010
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
Nike Triax CV10... • Answered on Mar 31, 2010
May I get the make and model # of the watch to help you more.
Nike Triax CV10... • Answered on Mar 25, 2010
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Nike Triax CV10... • Answered on Jun 25, 2008
Usually after changing the battery you need to "ac" it, which means to restart the ic, or else the light will keep on. please check there is a area on the pc board says "AC". all you need to do is use a metal pin to contact it. if it dosn't work then try press all push buttom at same time, it has the same function as press "AC"
Tsai
Nike Triax CV10... • Answered on Jun 09, 2008
Any local Jeweler will have this band or one that will work.
Nike Triax... • Answered on Aug 29, 2016
Nike Triax Fury 100 SuperYes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nike Triax... • Answered on Sep 30, 2012
Nike Triax Fury 100 SuperYou need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nike Triax CV10 Wrist Watch Logo
Popular Tags
16 questions posted
Top Nike Watches Experts
Lisa Christine
Lisa Christine
Terry
Terry
Bill Boyd
Are you a Nike Watch Expert? Answer questions, earn points and help others
View Most Popular
Triax Nike
  • Triax Nike
Most Popular Question
link watch heart monitor
  • Watches
