20 Most Recent NAD C355BEE Amplifier Questions & Answers
Schematic diagram
Try http://hifiengine.com/
12/7/2014 12:42:48 PM • NAD C355BEE... • Answered on Dec 07, 2014
Schematic diagram
check the pcb mounted fuses on the power supply board They look like resistors only they have 1 colored stripe. replace the open (resistance above 1 ohm) fuse and enjoy your amp.
3/24/2014 1:46:14 PM • NAD C355BEE... • Answered on Mar 24, 2014
Input selection indicators off
little mini light bulbs are blowing, remove top cover, remove 1 bulb, take it to electronics store and get replacements for them all (I think there are 5) reinstall the new bulbs and the cover. good to go
3/24/2014 1:38:50 PM • NAD C355BEE... • Answered on Mar 24, 2014
0answers
0answers
My C355Bee amplifier will not
This is usually called "protect mode". See the link below for an explanation. If the unit remains in this condition even after disconnecting all speaker wires, it likely will require service. Please update this if you need further information.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
5/29/2011 3:38:38 PM • NAD C355BEE... • Answered on May 29, 2011
0answers
NAD S200 one channel is not working
You have a fault in the power amp. Identify the faulty channel by following the input leads. As, a stereo amp is basically two mono amps put together. You can compare the bad channel with the good one. First thing to do is a visual look around. If you see something odd looking in one channel and it's the faulty one, compared with the good channel, you might have found the cause. Look at the devices or device on the heatsink especially. If nothing stands out, the next thing to do is test the channels. You can do this in two ways. First, by touching the parts on each channel (with power on) with an insulated screwdriver. If you get a buzz in one channel and nothing in the bad one, in the same places of course! You might have located the faulty device. You can do the same with a volt meter. The readings should be the same in each channel. Work forward from the end of the preamp stage. Don't bother with the power supply parts, as they are common to both channels. By the way, don't short anything!
2/25/2024 7:26:01 PM • NAD Audio... • Answered on Feb 25, 2024
I have a Nad Receiver T748 , I can not connect any device with HDMI at port 2, 3, 4, only port HDMI 1 is working.What should I do
I have nad t748 but not switching on the power on tha auto turn off
7/23/2023 4:01:40 AM • NAD Audio... • Answered on Jul 23, 2023
I have a NAD 1600 receiver for 40 years. It always worked fine!! I just moved it 15 feet to new room and volume seems stuck on high! Knob turns but volume doesn't change. What happened??
It is funny, I was just reading an article today about New Acoustic Dimension Cassette decks saying they were top of the line and equal to Nakamichi. The most likely reason is that the volume control needs cleaning with Electrical Switch Cleaner. You would have to remove the case and look. It is worth a quick spray. This says it has a motorized volume control. https://www.google.com/search?q=nad+1600+receiver+volume+on+high+volume ..
2/24/2023 3:31:57 AM • NAD Audio... • Answered on Feb 24, 2023
Where can I get a volume and balance control for a 1990 or so NAD 1300 preamp?
You can find volume and balance control components for the NAD 1300 preamp from a variety of sources. You can check with NAD directly, or look for parts on websites such as eBay or Amazon. Additionally, you may be able to find parts from audio/electronics shops in your local area.
2/4/2023 5:23:08 AM • NAD Audio... • Answered on Feb 04, 2023
Have a Nad 3020 using as preamp to Nad 2600 amp. Is there a way to hook up an equalizer
NAD (New Acoustic Dimension) was all the rage when I was into composite audio in the 1970s. Not sure why would want to tweak that sweet clear natural sound like the performers played it. Your problem will be that you are loading an amp to a pre amp. https://www.google.com/search?q=Nad+2600 https://www.google.com/search?q=Nad+3020 https://www.google.com/search?q=nad+3020+nad+2600+graphic+equalizer ..
3/5/2022 5:41:13 AM • NAD Audio... • Answered on Mar 05, 2022
Nad 326bee popping sound?
Does it occur on both channels at the same time, (power supply) or independant channels, (coupling capacitor).
2/18/2022 5:59:47 AM • NAD Audio... • Answered on Feb 18, 2022
NAD 5425 CD Player display light out
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
10/3/2021 4:04:40 PM • NAD Audio... • Answered on Oct 03, 2021
3answers
Nad t753 volume control knob doesnt work
I'm going to assume that you mean it jumps around, volume up/down by itself? If so, you have a bad rotary encoder. If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
9/13/2021 12:24:27 AM • NAD Audio... • Answered on Sep 13, 2021
4answers
How to reset a NAD L54 DVD reciever?
This is the technical solution, you have to open the unit:Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.The unit will then boot up in factory default.Henrik Pedersen
4/13/2021 5:28:32 AM • NAD Audio... • Answered on Apr 13, 2021
My NAD T750 will not power up unless I tilt it on its edge. Then all controls are working.
Bad connections along the front PCB.
2/7/2021 4:36:36 PM • NAD Audio... • Answered on Feb 07, 2021
NAD C355BEE Amplifier Logo
9 questions posted
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • NAD Audio Players & Recorders
Most Popular Question
c355bee amplifier will not
  • Audio Players & Recorders
