20 Most Recent DISH Network 32 Ir 137180 Remote 5900 3100 4100 Questions & Answers
I would try changing the batteries. If that doesn't do the trick then you either need to reprogram the remote or just call Dish and they will issue you a new remote.
DISH Network 32... | Answered on May 07, 2014
Anthony Stewart,
I hope this has been resolved for you by now, but if not I would be happy to help! Below I have listed the steps to program the remote to both the TV and Receiver. If you have any other questions, let me know!
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if it works.
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
DISH Network 32... | Answered on Aug 25, 2012
hanque,
I would need more information on if you're trying to program it to the TV or the receiver to provide you a specific answer, but to get you started I do have some information you could use.
To program your remote to your receiver you can find the instructions at this link based on your receiver: http://www.dishnetwork.com/SupportSection/remote-setup
To program your remote to the TV or other equipment you can find the codes at this link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx.
If you can provide more information on what you're looking to address I can definitely assist you further. You can reach me here or at [email protected]!
Tommy Faust
DISH Network
DISH Network 32... | Answered on Oct 18, 2011
It sounds like the remote would need to be address to the receiver. This needs to be done from the main TV location, and I have listed the steps below!
6.) Test remote and see if works.
Hope that helps!
Tommy Faust
DISH Network
DISH Network 32... | Answered on Jul 07, 2011
Have you tried unplugging the receiver for 10 seconds? Also, do the other functions on this remote work properly? You can also try reprogramming the remote by pressing the system info button on the front of the receiver and pressing the "SAT" button you should hear three tones confirming it worked. If you need further assistance e-mail me at [email protected]
Daniel Busa
DISH Network
Customer Service
DISH Network 32... | Answered on Jun 29, 2011
Hello, this sounds like you have a problem with your DISH remote. If you are, here are some steps to get it working. The first set of steps is to get it working with the tv, the second for getting it working on your receiver.
TV:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
RECEIVER:
1. Go to System Info Screen
2. Press and release the SAT button on the remote one time
3. Press the black and red record button 3 times.
4. The number next to the remote address should change.
Becki Barned
DISH Network Customer Service
DISH Network 32... | Answered on Feb 16, 2011
trifonas_ger
If you are trying to use your Samsung TV remote, it will not work with our DISH receiver. Some universal remotes can be programmed to the receiver but you may not get full functionality with the universal remote. Our remotes are designed to allow for functionality for the TV if programmed to the DISH remote (volume, on/off). I hope this helps.
Ray Calo
DISH Network
DISH Network 32... | Answered on Feb 05, 2011
Hey there! This is Becki Barned with Dish Network customer service. This is no problem!!! First, make sure that you are in front of the receiver for this process, then try these simple steps. Hope this helps!!!!! http://www.dishnetwork.com/SupportSection/remote-control
DISH Network 32... | Answered on Dec 25, 2010
The most common way is unplug the power cable for 5 minutes.
DISH Network... | Answered on Jul 07, 2014
THEN CONTACT THE MANUFACTURER WE DO NOT SUPPORT THEM
Home Security | Answered on Jun 10, 2020
You can also reset their password to "1234" or click "Forgot your Password" to have their password emailed to them (the Email field for the user ID is the email address used for this password reminder). In addition, the Account field displays each user's assigned account number.
https://tech.napcosecurity.com/index.php/faq/details/id/467/?
Home Security | Answered on May 30, 2020
To reset password of your CCTV DVR press and hold the ENTER button for 15 to 30 second until the DVR restart's. After the restart you DVR default wizard will come up the same way like if you are setting up the DVR for the first time.
https://www.youtube.com/watch?v=dmspTHBS7e8
Home Security | Answered on May 29, 2020
The two types of cables used for the installation of Security Cameras and Digital Video Recorders (DVRs) are Plug and Play Cables (PnP) and RG59 Coax Siamese cable.
https://www.cctvcamerapros.com/Security-Camera-Cable-s/58.htm
Home Security | Answered on May 16, 2020
Pasward loked how to open
Home Security | Answered on May 09, 2020
Press and hold the enter button on the DVR for 15 to 30. Everything will go back to same settings. Default password will be either 888888 or 666666. User name is Admin
Home Security | Answered on May 06, 2020
I need help to fix my safety box I need a # to call my email is [email protected]
Some people damaged my box how much it will cost me?
Home Security | Answered on Apr 24, 2020
https://www.youtube.com/watch?v=xFkV6Ic_htc
https://www.youtube.com/watch?v=U9GhoL9xFb0
Home Security | Answered on Apr 18, 2020
DISH Network 32 Ir 137180 Remote 5900 3100 4100 Logo
15 questions posted
Top DISH Network Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • DISH Network Home Security
Most Popular Question
remote doesn 39 t work won 39 t
  • Home Security
