20 Most Recent Curtis LCD2424A 24 in. LCD HDTV Questions & Answers
I'm assuming your Antenna is connected to your TV with a co-axial cable? If so, please make sure you have run the Analogue/Antenna/Air channel scan correctly:
1. Switch the TV on
2. Press the "MENU" button on the Curtis remote supplied with the TV.
3. Press the RIGHT arrow button five times to highlight the "Channel" menu
4. Press the "ENTER" button or the DOWN arrow once to open the "Channel" menu
The Air/Cable option should be highlighted.
5. Use the LEFT/RIGHT arrow buttons to set the "Air/Cable" option to "Air"
6. Press the DOWN arrow to highlight "Auto Scan"
7. Press the "ENTER" button or the RIGHT arrow once to start the automatic channel scan.
When the scan has finished, the TV should automatically return to viewing mode. If not, just press the "EXIT" or "MENU" button on the remote to close the menu.
You also need to make sure the correct INPUT/SOURCE is selected on the TV:
1. Press the "SOURCE" button on the Curtis remote
2. Use the UP/DOWN arrows to highlight "TV" in the INPUT SOURCE menu
3. Press the "ENTER" button on the remote to select "TV" and close the INPUT SOURCE menu.
This should be all you need to do to watch your TV from an antenna source.
Please post back if you are still unable to get it to work and need further assistance.
Regards,
BElectric
Curtis LCD2424A... • Answered on Apr 10, 2016
hi if your tv has hdmi this would be better, hope it helps regards shaun
Curtis LCD2424A... • Answered on Mar 26, 2014
For my Samsung its the content button on the remote, then under channel manager you move to highlight ALL channels and add the ones you want.
Curtis LCD2424A... • Answered on Aug 11, 2013
10047, 10054, 10154, 10451, 10093, 10060, 10702, 10030, 10145, 10166, 10016, 10056, 10466, 10747, 11919
Curtis LCD2424A... • Answered on Jul 24, 2012
The tv only 3 or 4 months olds take the tv warrenty repair or return it were u bought it trade it in for another new tv.This tv the main tv Tuner signal itself have problems,if after scanning channels and come up with nothing.
Curtis LCD2424A... • Answered on Aug 31, 2011
Your TV may not be compatible. What is needed is a cable box, it handles all of the channels and the TV stays only on channel 3 or other input from the cable box.
Curtis LCD2424A... • Answered on Jun 20, 2011
The tv have problems,take the tv back where u bought it to get a new replacement.
Curtis LCD2424A... • Answered on Mar 14, 2011
Katie - Sorry, the USB port on the TV (as on many TVs) is strictly for service use and has no function available to the consumer.
Regards and Thanks for using Fix Ya.
Mikeywaf
Curtis LCD2424A... • Answered on Mar 12, 2011
Connect it to the scart socket on the tv, then select the external input button on your tv remote. It may say "Input" or have an icon of a small tv screen with an arrow pointing into it. You may have to press this button more than once to cycle through all the inputs.
Curtis LCD2424A... • Answered on Jan 16, 2011
Well you may please follow the following steps -
Method first - Universal Remote Control setup:
1. Turn ON your TV.
2. Press FUNC button.
3. Press TV button.
4. Enter 2-digit code No.
5. Press TV button.
6.Press POWER button to confirm.
or
Method second - Search Mode Method
1. Turn ON your TV.
3. Press TV button.
4. Repeatedly press POWER button until TV go's OFF.
5. Press TV button to confim.
Red LED will blink 3 times if wrong input is detected.
or
You can try 00,06,11,15,21,50 codes.
Good Luck!!
Thanks
Curtis LCD2424A... • Answered on Oct 14, 2010
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right column. View it on a desktop or in web View. Mobile view has no search box...
Curtis Televison... • Answered on Jun 06, 2021
Yes, plug it into the HDMI port and enjoy!
Curtis Televison... • Answered on Feb 09, 2021
Curtis LCD2424A 24 in. LCD HDTV Logo
30 questions posted
Top Curtis Televison & Video Experts
Abhinandan  Patil
Abhinandan Patil
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Curtis Televison & Video
Most Popular Question
hook antenna back not
  • Televison & Video
