20 Most Recent Samsung PN63C590 TV Questions & Answers
check the display strip. un plug it and fix it
Samsung PN... | Answered on May 14, 2019
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Samsung PN... | Answered on Jan 05, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Samsung PN... | Answered on Jun 30, 2016
Return to the initial set up procedure and disable it.
Samsung PN... | Answered on Oct 27, 2015
www.samsung.com/us/support
Samsung PN... | Answered on Feb 01, 2015
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Samsung PN... | Answered on Sep 13, 2014
Have you checked the sustain board/s. If you wish to get some details about how to check a plasma TV, visit the site linked here. It has details with illustrations. The shown is for an LG brand plasma, but all the plasma TVs will have same configuration and checking procedure, irrespective of its brand and screen size.
Samsung PN... | Answered on Aug 27, 2014
yes take it to a tv tech would be your best bet.
regards
shaun
Samsung PN... | Answered on Apr 21, 2014
Check and replace the damaged component/s at its main power regulator board [SMPS]; or, replace this board as card basis. Contact any service technician. After replacement, the should be some voltage adjustments to be done to Plasma TVs.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Samsung PN... | Answered on Mar 24, 2014
Refer its user manual for details.
Samsung PN... | Answered on Jan 05, 2014
Samsung PN63C590 TV Logo
1 questions posted
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
PN Samsung
  • PN Samsung
Most Popular Question
our plasma television narrow vertical
  • Televison & Video
