20 Most Recent
Haier hl19sl2 19 in TV Questions & Answers
No sound
Try to use your dvd or cd player and direct it to your tv if there is a sound the fault is not in your tv. If you are using a digital box try to check the cables specially the one that connects your audio try this it may help.
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat.
The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions.
I hope this helps. Please add a comment with the model of your unit for further information.
