20 Most Recent Panasonic TCP42C2 42 in TV Questions & Answers
You will need the remote for this function.
Panasonic... | Answered on Sep 30, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Panasonic... | Answered on Dec 12, 2015
i say amazon or ebqay or shopjimmys
Panasonic... | Answered on Jul 16, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Panasonic... | Answered on Feb 25, 2014
To get more details about the screws size and others, you have to download the repair manual to this set by internet, and have to look into the disassemble section. If you wish to get some details about these, check the site linked below. It has disassembley procedure to many band TVs, including Panasonic. Check for your model, by its left side bar. http://electronicshelponline.blogspot.com/
Panasonic... | Answered on Jul 01, 2013
Panasonic... | Answered on Mar 29, 2013
This will depend on what type of wall you are fixing it to. It's a pretty big TV so for a solid timber brick or cement block wall I would suggest M5 or M6 x 50mm
If it's a hollow stud-work wall you will need to use specialist hollow wall fixings such as toggle bolts. again M5 or M6 thickness would be appropriate but you would be well advised to try to screw into the actual stud-work rather than just rely on plasterboard to support such a weight. You can buy an electronic stud detecting tool from DIY stores relatively cheaply.
Panasonic... | Answered on Mar 21, 2013
It sounds that the main board is faulty. I2C bus short. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Blinking codes and fault descriptions are given in detail in one among the posts.
Panasonic... | Answered on Oct 06, 2012
When you say 'closed captions' I assume these can be seen but cannot be selected. Kindly look through the operation manual and check whether such features are there in the TV.
Panasonic... | Answered on Jul 31, 2012
Panasonic TCP42C2 42 in TV Logo
84 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
panasonic tc p42c2 red light blinks 10
  • Televison & Video
