20 Most Recent
Philips 19PFL3504DF7 19 in. TV Questions & Answers
I am trying to hook
This tv has speakers, use those. If you want to use external ones connect them to the audio output RCA connectors at the rear of the Roku - the red and white ones.
9/2/2011 6:46:49 AM •
Philips...
Answered
on Sep 02, 2011
My phillips 19pfl3504df7 suddenly went
Look for a button on your Philips remote labeled Format. This button will cycle through the picture formats available for that signal. Press it until you find one you like.
Hope that helps!
7/19/2011 3:57:32 AM •
Philips...
Answered
on Jul 19, 2011
My tv has a buzzing
Hello, usually this kind of error stems from electrolyte capacitors, which are in power. Sometimes you can see that the capacitors were swollen. Replacing capacitors required soldering equipment, tin, pewter cleaner. Be sure the polarity of the condenser, and its correct value. Good luck!
4/22/2011 2:16:39 PM •
Philips...
Answered
on Apr 22, 2011
I have a 19" Philips TV; model 19pfl3504d/f7 and
Hello there telling you what to buy is not the solution but knowing how to use what you buy. To avoid spending your money buying things which you wont be able to implement just get an expert who is not an electronics illiterate to check it. Most likely your logitech speakers will work just fine.
Hope this solution has been helpful?
12/2/2010 1:30:18 PM •
Philips...
Answered
on Dec 02, 2010
Hello-I have a 19
connect a laptop to the set, using the usb port contact phillips on line download the old flash to the computer save the old flash download as a file and, to the usb flashdrive connected to your laptop reload the set either with the laptop or, the flashdrive unplug the set first then: remove the flash drive
7/17/2010 1:52:32 AM •
Philips...
Answered
on Jul 17, 2010
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
