20 Most Recent Sony KDL32BX300 32 in. TV Questions & Answers
Hi man 1 Look I don't know anything anout these "boards", etc. Might I suggest that before you go into "BIG Bucks" Have you checked for eliminating possible things that can interfere with your HDTV. I'd suggest that you examine the lines that go and input your picture as a possible issue. I had this with my PC HD Monitor, simply by overlaying power cables, ethernet lines, or even power cords from things nearby. Also, if you are on the 1st or 2nd floor, what is under you ? Is there a fluorescent light box, proximity to the circuit breakers, you see what I mean? Usuall these HDTVs are very well made, & changing parts is "unusual", but hey I could be totally off 100% on this one. My name here should be " CHARLIE CHEAP" !! I hate parting with my dough, and when there's a problem, it's amazing how often "the darndest things" happen, that normally we'd never think of. I sincerely wish you good luck, and "Low to NO costs" ,OK?
Geoff
Sony KDL32BX300... | Answered on May 09, 2017
Dear Ing
You need to load new software on your board - this to enable the main board to read the LCD Panel ID in the set.
Go to your local SONY website and search for a download for this software, make sure you download the correct software on to a USB drive. Unzip the file and keep the folder in the root of the USB. You can now delete the ZIP file and check that you have the bin file in the folder with the software.
Insert the USB in the back of the set. Make sure the set is off while you do this. Insert the power socket into the wall socket. Check that the light on you USB drive starts to flash ( Twice ) now switch your set on and wait. You will see the green and amber lights illuminate to show you the software is downloading. The set will switch of after more or less three minutes, now the amber and red lights will illuminate as the set unpacks the data and the set will switch off again and reboot to execute the software.
Once the set asks you for the language selection - You have been successful!
Sony KDL32BX300... | Answered on Dec 01, 2013
The price of the screen only will cost around 2/3rd of the total cost of a new TV.
Sony KDL32BX300... | Answered on Oct 06, 2013
Any standard headphones with a 3.5mm jack will be compatable to the audio out.
Sony KDL32BX300... | Answered on Sep 18, 2013
It sounds that the main board has the fault. Checking and locating the faulty component to this board, is a very skilled work. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Sony KDL32BX300... | Answered on Aug 02, 2013
i have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
Sony KDL32BX300... | Answered on Mar 03, 2013
The main power regulator board has damaged. Check and replace it.
Sony KDL32BX300... | Answered on Jan 21, 2013
if no stand by light indicator, it was a power supply board failure. check for blown primary fuse .
Sony KDL32BX300... | Answered on Aug 17, 2012
what do you mean how is the speakers hucked up
Sony KDL32BX300... | Answered on Jun 04, 2012
Time for a new TV---cost of just the part alone wholesale is more than another set---A lot this size the Panel or screen unit is not even available.
Sorry but this is the case.
Sony KDL32BX300... | Answered on Apr 18, 2012
Sony KDL32BX300 32 in. TV Logo
60 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
part number lcd screen kdl32bx300
  • Televison & Video
